Caliper Mount Bolt
Caliper Mount Bolt
Tap to enlarge
£2.98
Product Information
Specification
Main caliper mounting bolt, the large one that holds the caliper mount to the hub.
Price is PER BOLT
Product Code09283-40027 Equivalent
ManufacturerBigJimny
ConditionNew
Weight0.024kg
Products related to this item
Brake disc - Suzuki Jimny (107mm)
£22.00
Front ABS Sensor Assembly (Suzuki)
£250.68
Front Hub Bolts
Front Hub Bolts
£3.00
Front Pad Fitting Kit
£18.70
Brake disc - Suzuki Jimny (108.3mm)
£35.50
Caliper Fitting Kit (Aisin)
£16.50
Caliper Piston Repair Kit (Aisin)
£25.00
Caliper Piston Seal Kit (Aisin)
£12.00
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
