Your basket is empty.
Tap to enlarge
Kit containing replacement fittings for an Aisin Caliper on a Suzuki Jimny.
This kit is for one caliper.
It contains:
These are the parts that typically corrode and stick, causing your brakes to stick on. The rubber seals in particular need care and should only use the special grease to stop the rubber being affected by oils.
eCommerce by CubeCart
