BigJimmy Store uses cookies. For more detailed information about these cookies please see our
privacy policy
. Please accept to continue or block all non-essential cookies.
£0.00
Your Basket
Your basket is empty.
Added to Basket
£ GBP
Login
Register
Advanced Search
Please enter a search keyword
Advanced Search
Shop by Category
SJ/Sierra - Gen2
SJ/Sierra - Gen2
Parts & Service
Parts & Service
Bearings and Seals
Engine Parts
Steering, Axles & Bushes
Body Panels and Parts
Nuts, Bolts and Fittings
Hardware and Body
Jimny - Gen3
Jimny - Gen3
Parts & Service
Parts & Service
Bearings and Seals
Filters and Cooling
Engine Parts
Engine Parts
Engine Parts
Sensors
Belts
Braking/Clutch parts
Electrical
Body panels and parts
Suspension
Hardware & Body
Modification Parts
Accessories
Promotional
Jimny - Gen4
Jimny - Gen4
Parts & Service
Parts & Service
Electrical
Brakes & Clutch Parts
Engine Parts
Bearings and Seals
Filters and Cooling
Accessories - 2019+
Modification parts
Modification parts
LED Bulbs
Other Suzuki Models
Home
SJ/Sierra - Gen2
Parts & Service
Bearings and Seals
Bearings and Seals
Sort by
-- Please Select --
Name (Z-A)
Name (A-Z)
Date Added (Newest First)
Date Added (Oldest First)
Price (High-Low)
Price (Low-High)
Kingpin Bearing Kit (Premium - Koyo)
Why "Premium" as there are other kits on the Internet..... Bearings are Koyo - these are EXACTLY the ones supplied…
£24.50
Add to Basket
£24.50
Add to Basket
Transfer Box Oil Seal Kit - SJ
This kit replaces the three oil seals on an SJ Transfer Box, ideal if you are building a RockLobster to fit on your SJ o…
£7.50
£7.50
Transfer Box Gasket Set - SJ
For those of you building a RockLobster or simply rebuilding a Transfer Box on your Suzuki SJ, these are the gaskets req…
£11.48
Add to Basket
£11.48
Add to Basket
SJ Shifter Sheet
Genuine Suzuki Shifter Sheet - 29541-80051 Fix that wobbly shifter. If shows out of stock I can get these in…
£19.60
Add to Basket
SJ Shifter Sheet
£19.60
Add to Basket
64
72
128
Loading
Featured Product
Spark Plugs (Budget)
£13.16
Best Sellers
£24.50
KingPin Shim Kit
£3.50
Hub Nut Tool
£41.00
Swivel/Knuckle Seal
£30.24
Suzuki Jimny Wobble Kit
£87.36
Waterproof Grease
£10.00
Kingpin Bearing with Swivel Seal Kit (Premium - Koyo)
£50.00
Loctite Premium Copper/Silicone Sealant
£9.50
Front Axle Oil Seal
£3.00
Rear Wheel Bearing Kit (ABS - Gen3)
£83.00
Top
eCommerce by
CubeCart
