Brake disc - Suzuki Jimny (107mm)
Tap to enlarge
£22.00
Product Information
Specification
Replacement brake disc
Note: discs come with two separate centre hole sizes, please ensure you order the correct one.
THIS IS A SINGLE DISC.
THIS IS THE 107mm fit disc!
Vehicles up to VIN 203804 require 107mm centre discs
Vehicles from VIN 203804 require 108.3 mm centre discs
Product Code4805
ConditionNew
Weight6kg
Products related to this item
Brake Bleed Nipple (M10 x 1)
£2.10
Front Hub Bolts
Front Hub Bolts
£3.00
Front Brake Pads
Front Brake Pads
£19.82
Front ABS Sensor Assembly (Suzuki)
£250.68
Caliper Mount Bolt
Caliper Mount Bolt
£2.98
Brake disc - Suzuki Jimny (108.3mm)
£35.50
Brake Bleed Nipple (M8 x 1.25)
£2.60
Front Pad Fitting Kit
£18.70
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
