Waterproof Grease
Waterproof Grease
  • Click to enlarge
£12.58
Product Information
Specification
A special grease that I use specifically for my Kingpin Bearings. This is a VERY sticky grease that appears to adhere to anything and therefore I feel is ideal for the wet environment of the Jimny Hubs.
Very high temperature lithium based grease suitable for aggressive environments. Water and saltwater resistant and offers protection in severe conditions including high loads, very high temperatures, rust and corrosion. Heavy Duty - High Temperature
A smooth, dark blue, E.P. Lithium complex multi-purpose grease manufactured in a NLGI #2 consistency- with the added benefits of a high density polymer to provide optimum service under most ambient temperature conditions. For use from -29°C (-20°F) to 293°C (560°F). This distinctive multi-functional lubricating grease has very good mechanical stability (won’t thin out under normal usage), has excellent resistance to water wash out, clings to metal surfaces under severe conditions as it effectively reduces the coefficient of friction. Maxima Waterproof Grease is fortified with non leaded extreme pressure additives for high load carrying ability and extra protection under shock loading conditions. Rust & corrosion inhibitors provide a further margin of superior performance and protection under a wide variety of adverse operating conditions. This high temperature lithium complex grease will work on bearings next to disc brakes as well as boat trailer axles & hubs used in salt water environments.
Product CodeGREASE
ManufacturerMaxima
ConditionNew
Weight0.55Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
