Kingpin Bearing Kit (Premium - Koyo)
Tap to enlarge
£24.50
Product Information
Specification
Why "Premium" as there are other kits on the Internet.....
  • Bearings are Koyo - these are EXACTLY the ones supplied by Suzuki, not an equivalent manufacturer, not a Chinese copy, not described as OEM specification (ie, like Suzuki specifications, but not Suzuki)
This is the real deal, note that there are FAKE bearings on the Internet
Fits all Suzuki Jimny models and years.
Kit consisting of TWO Kingpin bearings and ONE axle oil seal.
This kit consists of the parts needed to change the Kingpin bearings on one side of the front axle.
It contains a pair of 30302J Bearings and a 26 x 38 x 8 R23 Oil Seal which is the small one that fits inside the axle end. (Note the current shipped seal is 8mm )
This kit consists of the genuine Koyo Bearings, as fitted by Suzuki. These are not "white box" or Chinese copies or equivalent brands.
This kit contains the SAME bearing as the Suzuki 09265-15006 bearings and an 8mm equivalent of the 09283-26016 Oil Seal.
This kit also fits a broad selection of the SJ Suzuki range as well.
A link to the "How to" describing how to change the bearings on a Jimny is HERE
You can find out more about curing Death Wobble here - http://www.bigjimny.com/mediawiki/index.php/Death_Wobble
How to check for fake Koyo bearings
   I only sell genuine bearings  !
The genuine bearings have a label like this, it has a barcode, a QR code and holographic strip. The holographic strip has a Koyo logo in it that turns to iTekt as you move your head. Once you have seen the hologram you can then look up the QR code in the WBA Authenticator App and it will confirm that the bearing is genuine.
Product CodePremium Kingpin Bearing Kit
ManufacturerBigJimny
ConditionNew
Weight0.28kg
Products related to this item
Swivel/Knuckle Seal (Suzuki)
£32.08
Kingpin - Genuine Suzuki
£74.26
KingPin Shim Kit
KingPin Shim Kit
£3.50
Customer Reviews
Average Rating: 0
Fixed death wobble
12345
Replaced the nearside king pin bearings on Saturday in around 4 hours following thebigjimny instructions. My 10 year old Jimny now drives like a new car, no death wobble and no more oily leaks from the hub. A sound investment!!Steve (28 Sep 2014, 15:41)
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
