Customer Reviews
Average Rating: 4.3
Finally, death wobble fixed.
I bought my 2014 un-doctored Jimny 18 months ago with 65k on the clock. It had horrendous death wobble around 40 - 50. I changed kingpins, kingpin bearings, drag rod links, steering rod links, discs and pads, 4 * springs & shocks. Death wobble persisted. Brakes were binding, so replaced a caliper and rebuilt the other. Still had death wobble. Had wheels re-balanced twice. The shims were one of the first things I'd bought but I never bothered with them because I'd decided to the job 'properly' by replacing the kingpins and bearings. As a last resort I fitted a medium shim to each top bearing. No more death wobble - not even a slight wobble. All those parts and it's been eliminated by those 2 shims ...Mike (Dec 30 2021, 21:20 PM)
Wobble solved
We had terrible death wobble on our Jimny, which has a 3" lift and wide tyres on for farm use, particularly around 25-30mph. I'll admit I was a bit sceptical that something so simple would cure the problem but it really has been amazingly effective. Took about 2 hours to fit and test but the wobble has been more or less eliminated, even under braking. Would definitely recommend given the value: even if it doesn't work it's worth a try.Jonny (Nov 16 2020, 14:41 PM)
It did it!!
The kit worked perfectly on my '09 Jimny with modified suspension and bigger tires. Previously tried replacing the off-road tires (they were unevenly weared down) with more urban ones, but the wobble was indeed worse! Putting these shims made the wobble disappear 100%. Couldn' t be happier with the result!Jacobo (Feb 01 2020, 06:56 AM)
It Works
No more "Death Wobble".aufallenvieren (May 12 2016, 04:43 AM)
No more steering wobble.
Shims were a perfect fit. Completely fixed the steering wobble at 40mph on my 07 JLX. Mine took 0.2mm on the passenger side top and bottom, and on the drivers side 0.5mm top and 0.2mm lower. Very happy with the result.Matt (May 07 2016, 20:02 PM)
Write Review
