Idling problems
  • jb33w
11 years 11 months ago #131095 by jb33w
Replied by jb33w on topic Idling problems
j999pre wrote: Yea
thanks, I'll check it. Strange thing is that I can't find this filter nor the map sensor on engine/intake manifold scheme for my car. But I definitely should have one cause I have IAT sensor in place. Can't check it right now under the hood, but it's indeed a good idea.
  • mickt
11 years 11 months ago #131232 by mickt
Replied by mickt on topic Idling problems
What engine have you got in the car? The dvd has both the single and dual cam engines and the MAP are in different places. That is why I mentioned the car I checked the idle valve on was the dual cam. It looks like that valve is in the same position on both going by the diagram.
Member j99pre might be able to help you with a replacement!
  • jb33w
11 years 11 months ago - 11 years 11 months ago #131304 by jb33w
I've g13B SOHC engine (16 valve), the one with timing belt. It's quite cold outside so I don't dare to visit my garage.
Also ordered the replacement part from chinese site, we'll see how it goes.
Last edit: 11 years 11 months ago by jb33w.
  • mickt
11 years 11 months ago #131333 by mickt
Well your engine should have the MAP sensor where j99pre mentioned according to my dvd.
  • jb33w
11 years 11 months ago - 11 years 11 months ago #131421 by jb33w
you're right , as far as i know it either has map + temperature sensor or MAF (I know that I have temp sensor, so MAP should be there.).
Going to check this one on Saturday, and also install the replacement IAC valve, hope they'll get it delivered till then.
I've attached a throttle body scheme and can't find the MAP on it, attached image is taken from original parts catalog.
Thanks for your help!
Last edit: 11 years 11 months ago by jb33w. Reason: typo
  • mickt
11 years 11 months ago #131453 by mickt
Find enclosed copy out of my dvd. Hope it helps.
File Attachment:
File Name: IMG_2014-12-03.pdf
File Size:820.05 KB
File Attachment:
File Name: IMG_0001.pdf
File Size:637.9 KB
Time to create page: 0.109 seconds
