Idling problems
  • mickt
11 years 10 months ago #134687 by mickt
Replied by mickt on topic Idling problems
I have got myself another Jimny, a soft top with the SOHC engine. I will check the idle valve on this car to see what the values are, hopefully tomorrow or Sunday.
11 years 10 months ago - 11 years 10 months ago #134690 by Rhinoman
Replied by Rhinoman on topic Idling problems
jb33w wrote: Strange thing that IAC he sent behaves the same as mine, it measures as having 1 open circuit.
The schematic in the FSM (for the M13A) shows the third wire as a separate ground so it won't have connectivity to the other wires.
Last edit: 11 years 10 months ago by Rhinoman.
The following user(s) said Thank You: jb33w
  • BigT
11 years 10 months ago #134721 by BigT
Replied by BigT on topic Idling problems
I think it's time to start at the beginning again and do a thorough diagnostic examination of the engine.. A simple tool like a vacuum gauge would be my starting point, followed by a pressure check on the fuel system, make certain the pressure regulator is working as it should be.
The workshop manual gives a fairly good guide to component testing.
  • mickt
11 years 10 months ago #134727 by mickt
I have just checked my soft top Jimny with the SOHC engine. Engine cold using my AVO again I got the following readings. Middle pin to top pin gave 9k ohms and middle pin to bottom pin gave 1450 ohms. Hope this helps.
  • jb33w
11 years 10 months ago - 11 years 10 months ago #134847 by jb33w
Replied by jb33w on topic Idling problems
thanks Rhinoman,
I've found this on wiring diagram, and thought it should have some resistance on both pins.
Good idea , BigT, will examine injectors first.
Last edit: 11 years 10 months ago by jb33w.
  • jb33w
11 years 10 months ago - 11 years 10 months ago #134848 by jb33w
mickt wrote: I have just checked my soft top Jimny with the SOHC engine. Engine cold using my AVO again I got the following readings. Middle pin to top pin gave 9k ohms and middle pin to bottom pin gave 1450 ohms. Hope this helps.
thanks for making the measurements, it's becomes the "mystery of IAC" :)
Does it have the same part number as mine?
Time to create page: 0.106 seconds
