Idling problems
  • jb33w
12 years 2 days ago #129715 by jb33w
Replied by jb33w on topic Idling problems
Hi, mine is too old and doesn't have OBD2, so I can't check with a computer. However I checked it using the method described in manual and it reported NORMAL(12) code.
I'm going to replace IAC valve with known good one and see what happens(I still have suspicions that it's buggy). Next step will be ECM check, but it's hard to find a decent one in my area for testing.
  • jb33w
12 years 1 day ago #129834 by jb33w
Could anyone measure and share the resistance between pins on their IAC valve?
  • 2013gary
12 years 19 hours ago #129921 by 2013gary
Replied by 2013gary on topic Idling problems
Rhinoman wrote:
2013gary wrote: I have a similar problem to this. After changing the front pads recently I was pumping the brakes to bed them in and I noticed that the revs were going up!
Vacuum leak somewhere around the servo, maybe a leaking servo diaphragm.
Sorry to sound thick but is this anything to do with the vacuum hubs? Or is it a separate vacuum system. I recently replaced my hubs with manual ones and as te flashing 4wd light didn't bother me when 4wd was selected I didn't block the pipes or anything.
  • jb33w
12 years 17 hours ago #129927 by jb33w
Afaik, there no separate vacuum pump so the system should be the same, but mine 4wd is working well.
If you could measure the resistance between middle connection pin of your IAC valve and 2 others I'd highly appreciate.
  • jb33w
11 years 11 months ago #130033 by jb33w
anyone with with Ohmmeter please? it takes just 1 minute.
  • jb33w
11 years 11 months ago #130838 by jb33w
Got Ohms?
Time to create page: 0.105 seconds
