Idling problems
- mickt
11 years 11 months ago #131749
by mickt
Replied by mickt on topic Idling problems
Well you have lost me there Rhinoman. What is the point of having a instrument, any instrument, calibrated to measure, in this case, resistance, if it cannot measure that value? I am not an electrician but have used meters all my life both on aircraft and cars and in the home and have used both digital and the analogue and prefer using the older machines. They are quality items, made in the UK, when we made everything, and are reliable. Now unless there is something magical at play, when is a resistance value not a resistance value? Please enlighten me as I agree the values we both got are massively different so if there is something at a basic level I don't know about I would appreciate the chance to learn something knew.
- BigT
11 years 11 months ago #131769
by BigT
Replied by BigT on topic Idling problems
Thats one quality bit of kit, used to use the mark 5 AVO 50 years ago, always very accurate.
11 years 11 months ago #131770
by Rhinoman
Replied by Rhinoman on topic Idling problems
On the back of the AVO it states the resistance that it has on each range. You need to calculate what the value would be without having that resistance in parallel with the load. For example, if you have a resistance of 20k/V and you're on the ten volt range when you put the meter across a 200k resistance, the combined resistance becomes 100k, so you need to calculate what the real voltage is for a circuit impedance of 200k.
The instruments are accurate, if in calibration, but not always correct. Its a long time since I used an AVO, I still have an AVO 8 but I've no idea where it is.
- mickt
11 years 11 months ago #131842
by mickt
Resistance is measured in ohms and the ranges selected are in ohms. You select the range the resistance you need to check is in and then measure it. All the calculations are surely done when the meter was made so that all the user had to do is read the indication. It does not make sense otherwise.
- jb33w
11 years 11 months ago #131865
by jb33w
Replied by jb33w on topic Idling problems
I think that a quote from the Avometer's manual could shed some light on this. Either way we'll learn something.
On wiki it states that "A design feature of Avometers was simplicity of use and towards this end, all measurements could generally be made using only two input terminals." It says nothing there about the need of additional calculations.
- mickt
11 years 11 months ago #131883
by mickt
That is exactly what I was trying to say in my thread!
Time to create page: 0.195 seconds
