Idling problems
- jb33w
11 years 11 months ago #131963
by jb33w
Replied by jb33w on topic Idling problems
so an update, waiting for parts, sensors etc, will do a massive check once they arrive.
- mickt
11 years 10 months ago #133217
by mickt
Replied by mickt on topic Idling problems
Any luck yet jb33w?
- jb33w
11 years 10 months ago - 11 years 10 months ago #134328
by jb33w
Hello mickt, just got my sensors pack from j999pre.
Strange thing that IAC he sent behaves the same as mine, it measures as having 1 open circuit. I don't think it's broken, but started thinking that it's an issue with my digital Ohmmeter and your Avometer. Changing other sensors didn't help, except MAP - it simply didn't fit and I was unable to test it.
The IAC part num is - 18137-64G0-0 / 136800-1090 (Denso)
Last edit: 11 years 10 months ago by jb33w. Reason: typo
- jb33w
11 years 10 months ago #134516
by jb33w
Was able to use the new map, by using different pins.
No positive effect was achieved. Still have an unstable idling.
- mickt
11 years 10 months ago #134549
by mickt
Looking back through the topic it seems that the engine temperature is the key to this fault. The input from the sensor to the ecu affecting the output to the idle valve might be the problem. When the engine warms up you say the idle gets erratic. Temp sensor at fault maybe??
- jb33w
11 years 10 months ago #134676
by jb33w
Temp sensor is fine, I've checked the sensor according to manual and it had correct resistance. Also it happens when the engine is hot, e.g. when I wait for a traffic light to change.
So far my ideas are:
1) ECU problem
2) problem with wiring, probably something adds noise so it sums with IAC control signal or some sensor's input, going to wire sensors and IAC one by one directly to the ECU and check.
1) ECU problem
Time to create page: 0.089 seconds
