Idling problems
  • jb33w
11 years 11 months ago #131031 by jb33w
Replied by jb33w on topic Idling problems
j999pre wrote:
jb33w wrote:
j999pre wrote: Try cleaning the little orange filter thingy leading the map sensor on the inlet plenum
You mean the EGR valve? I've cleaned it and it didn't hep.
No not the egr. Little inline valve towards the back of the inlet manifold on the thin rubber pipe to the map sensor
oh, sure, you mean the PCV valve. Checked it, It's clean and works perfectly.
11 years 11 months ago #131033 by j999pre
Replied by j999pre on topic Idling problems
No not the pcv, it's Orange and on the rear of the plenum near the bulkhead. Follow the pipe from the map sensor!
Grey pick up Jimny
  • mickt
11 years 11 months ago - 11 years 11 months ago #131045 by mickt
Replied by mickt on topic Idling problems
Just checked the daughters car for the IAC readings. Eng hot, ignition off the readings are as follows,
centre pin to right pin looking at receptacle 1100 ohms
centre pin to left pin 900 ohms I use a old fashioned analogue Avometer
her engine is the 1.3 dual cam 2003 car
Last edit: 11 years 11 months ago by mickt. Reason: added info
  • jb33w
11 years 11 months ago #131092 by jb33w
j999pre wrote: No not the pcv, it's Orange and on the rear of the plenum near the bulkhead. Follow the pipe from the map sensor!
the filter down the little hose from the map?
11 years 11 months ago #131093 by j999pre
Yea
Grey pick up Jimny
The following user(s) said Thank You: jb33w
  • jb33w
11 years 11 months ago #131094 by jb33w
mickt wrote: Just checked the daughters car for the IAC readings. Eng hot, ignition off the readings are as follows,
thank you very much! I have one open and one 65KOms. The IAC from local used parts store had readings close to mine, but i suspected it was wrong as well.
Thanks again for taking time to do this.
Time to create page: 0.124 seconds
