Idling problems
- mickt
I also found check of the IAT sensor which must input to the ecm to affect the idle valve.
At the ecu connector the resistance between pins c16-c17 should be 2.09-2.81 kohms
the voltage at pin c16 with ign on should be 2.0-2.7v
In one of your earlier posts you mentioned you were going to replace the IAC with a known good one. Did you?
- jb33w
mickt wrote: All my dvd says is to take the valve off and whilst still electrically connected watch for valve movement whilst turning on the ignition. That is why you need 2 people as the time lapse is so small, as mentioned, it is easy to miss, so repeat a couple of times to be sure of result. I imagine with the engine cold! Hopefully I will have the readings for the resistances tomorrow, weather permitting.
hi mickt, thanks for your help, the IAT appears to be fine, but I'll re-check it according to your data. Was looking for the good IAC but it was hard to find. New one costs 200 usd and I just don't want to spend this money without the confidence.
- mickt
- jb33w
jb33w wrote:
j999pre wrote: Try cleaning the little orange filter thingy leading the map sensor on the inlet plenum
You mean the EGR valve? I've cleaned it and it didn't hep.
No not the egr. Little inline valve towards the back of the inlet manifold on the thin rubber pipe to the map sensor
Grey pick up Jimny
- mickt
