Idling problems
  • mickt
11 years 11 months ago #130847 by mickt
Replied by mickt on topic Idling problems
When the daughters here on Sunday I will do that for you. Have you got a dvd workshop manual? In the copy I have it mentions how to check if the valve opens/closes correctly. 2 man job as it is all over in 60m/s apparently! It also gives a check of the voltage at the ecu pin for the valve at pin A18 of between 0 and 4.2v with eng at idle. Apparently it means taking the glove box out but that is not too difficult. Mind you if the car is not idling right then the reading might be meaningless! Obviously you do not disconnect the plug but access the back of the pin in situ!
  • jb33w
11 years 11 months ago #130875 by jb33w
Replied by jb33w on topic Idling problems
hi, I don't have the DVD but downloaded a set of PDFs with official manual. Didn't find how to check if it opens/closes correctly, tried to simulate the opening impulse from ECM and I suspect that the valve is doing wrong. Also measured the resistance between the pins mentioned and it gave me kOms which I think is also wrong (too much for small coils). Before going further with test/swap ECU and IAC valve I'd like to check if the resistance for the IAC is correct.
11 years 11 months ago #130879 by j999pre
Replied by j999pre on topic Idling problems
Try cleaning the little orange filter thingy leading the map sensor on the inlet plenum
Grey pick up Jimny
The following user(s) said Thank You: jb33w
11 years 11 months ago #130903 by safari
Replied by safari on topic Idling problems
hi i solved my idle problem yesterday after many attemts inc lamda sensor chang
took the aircleaner off for a while and cleaned the inlet pipe where the engine breather goes in , it was very dirty with oil cleaned it with thinner. today i spend a whole day running about with it with no problem
if u worry u die if u dont worry u still die so why worry
  • jb33w
11 years 11 months ago #130907 by jb33w
j999pre wrote: Try cleaning the little orange filter thingy leading the map sensor on the inlet plenum
You mean the EGR valve? I've cleaned it and it didn't hep.
  • jb33w
11 years 11 months ago #130908 by jb33w
safari wrote: hi i solved my idle problem yesterday after many attemts inc lamda sensor chang
hi, thanks, checked and cleaned every pipe going into the intake manifold, no luck.
Time to create page: 0.110 seconds
