Idling problems
  • jb33w
12 years 1 week ago - 12 years 3 days ago #129248 by jb33w
Idling problems was created by jb33w
Hello Guys,
my Jimny is from Japan(JB33W), right handed, manufactured in 1998. Some time ago I noticed that RPM began going up and down when idling, from 800 to 1500 and back. It happens very often when I warm up the car or just stay in a traffic jam. So I started looking for a possible cause:
  1. cleaned up the throttle body, including IAC valve, checked it and cleaned. -> no luck
  2. checked and cleaned EGR valve -> no luck
  3. changed sparks -> no luck
  4. tried to switch off any sensor I was able to find, to see if it changes rps to normal -> no luck
  5. checked PCV -> no luck
  6. checked hoses for air leaks -> no luck
  7. checked leaks in break booster-> no luck
I also noticed that sometimes shaking the car while it's idling changes the rpm. Also think of changing fuel filter with the pump but it's not that easy although doable.
I was looking for a solution to my problem for quite a long time now, and It'd be really great to get any advice from you.
Thanks in advance.
P.S. English is not my native language, please excuse my mistakes if any.
Last edit: 12 years 3 days ago by jb33w.
12 years 1 week ago #129255 by mlines
Replied by mlines on topic Idling problems
Air leak? - check the pipe work around the throttle body. Used something like "Easystart" spray around the throttle body and see if you can make the revs pick up when you spray it.
The following user(s) said Thank You: jb33w
  • jb33w
12 years 1 week ago - 12 years 1 week ago #129257 by jb33w
Replied by jb33w on topic Idling problems
Thx for advice. I tried to hear the hissing sound, but didn't try the spray.
Will look.
Last edit: 12 years 1 week ago by jb33w. Reason: typo
  • jb33w
12 years 6 days ago #129319 by jb33w
I was unable to find any air leaks, this problem becomes more and more puzzling.
  • jb33w
12 years 5 days ago #129429 by jb33w
Going to spend my weekend in the garage tinkering around with this idling problem, i'd highly appreciate any ideas before diving into complete system review.
12 years 5 days ago #129431 by Halford
Replied by Halford on topic Idling problems
I don't really know what I'm talking about but I've been around for a while and have heard others say ........
The temp sensor tells the ecu it is at running temp and the ecu adjusts the IAC.
If the sensor goes tits up the IAC will fluctuate.
First case is disconnect the IAC plug and if it settles at around 1400rpm you can more or less guarantee it's the temp sensor.
as I say, no idea but hope this helps
:S
Time to create page: 0.116 seconds
