BigJimnyMeet 2024
WAS DIRTYDOGZ JIMNY(SOFT TOP)
- bertbuckie
- Visitor
25 Apr 2011 05:52 #15441
by bertbuckie
Replied by bertbuckie on topic Re: DIRTYDOGZ JIMNY new shock
a disco classsic ?
- Fingers
- Visitor
02 May 2011 15:08 #15773
by Fingers
Replied by Fingers on topic Re: DIRTYDOGZ JIMNY new shock
thanks your all your advice dirtydogz
much appreciated.
You've done well;)
much appreciated.
You've done well;)
- Thank you received: 210
02 May 2011 15:45 #15776
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: DIRTYDOGZ JIMNY new shock
That's ok mate good luck with your JIMNY lets see lots of photos as you build it.
2002 JLX Soft Top
- Nelson83
- Visitor
03 Jun 2011 16:45 #17278
by Nelson83
Replied by Nelson83 on topic Re: DIRTYDOGZ JIMNY new shock
is there any chance you can post a few pics of the brackets you made to fit your A bar on dirtydogz? Did you need to do any welding? Im after one, and if its a case of making a few brackets, then im might give it a stab and follow your lead with one from a later jimny
03 Jun 2011 17:40 - 31 May 2013 22:42 #17279
by dirtydogz
2002 JLX Soft Top
Hi Nelson83
The brackets are from build base or wickes about £4 each.
No welding just bolt on.
This is the bracket l used but not from screwfix.
www.screwfix.com/p/heavy-duty-angle-brac...3mm-pack-of-25/69361
Hope this helps.
DIRTYDOGZ.
Hope this helps.
DIRTYDOGZ.
2002 JLX Soft Top
Last edit: 31 May 2013 22:42 by dirtydogz.
The following user(s) said Thank You: Nelson83
- Nelson83
- Visitor
03 Jun 2011 19:09 #17290
by Nelson83
Guessing the big bolt with the washer is the orginal mounting point and the two smaller bolts are the ones that youve had to moddify to fit? Looks fairly simple to do - dont suppose you have a link to your supplier at all
03 Jun 2011 19:18 - 07 May 2012 12:57 #17294
by dirtydogz
2002 JLX Soft Top
The big bolt with the washer, bolt the bracket to the a bar, and the two smaller ones bolt on to the jimny support bracket at the back of the bumper
stores.ebay.co.uk/NWautostyling
2002 JLX Soft Top
Last edit: 07 May 2012 12:57 by dirtydogz.
09 Oct 2011 05:06 - 13 Aug 2012 19:54 #23288
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: DIRTYDOGZ JIMNY (Update)2"Lift.
Received my 2" lift from Jimnybits on Tue 4 Oct, fitted on Sat 8 Oct, the job was very easy to do about 4 hours to fit +4 cups of tea.
The first photo is with 1.5" spring spacers
www.jimnybits.co.uk/shop/index.php?_a=viewCat&catId=1
Before
1.5" bits4vits spring spacers.
After
2" inch lift with Pro Comp ES1000 shocks
Before
After
2002 JLX Soft Top
Last edit: 13 Aug 2012 19:54 by dirtydogz.
- Nobby22
- Visitor
09 Oct 2011 06:18 #23301
by Nobby22
Replied by Nobby22 on topic Re: DIRTYDOGZ JIMNY (Update)2"Lift.
Its getting taller! Nice job, looks awesome. What tyres are you running. I running muds all the time and iam looking into some AT's.
Nobby
Nobby
- Nobby22
- Visitor
09 Oct 2011 06:21 #23302
by Nobby22
Sorry just look at the rest of your thread. There not AT's at all! What do they do to your MPG?
09 Oct 2011 06:22 - 09 Oct 2011 06:25 #23303
by dirtydogz
2002 JLX Soft Top
Maxxis 753 Bravo m/t 205/75/15.
26MPG DOWN HILL
26MPG DOWN HILL
2002 JLX Soft Top
Last edit: 09 Oct 2011 06:25 by dirtydogz.
- shootinginger@yahoo.co.uk
- Visitor
09 Oct 2011 07:14 #23307
by shootinginger@yahoo.co.uk
Replied by shootinginger@yahoo.co.uk on topic Re: DIRTYDOGZ JIMNY (Update)2"Lift.
i know it sounds strange but if you a get a normal wheel that the speedo is set up for, put a mark on the tyre and a mark on the floor, roll it to it has done a complete circle then mark the floor again and then do the same process fith you bigger tyre you see you be doing about 10inches + each rotation of the wheel, so my made said, it doesnt register on the speedo but will probly take a little more fuel, just somethign to bear in mind!
Time to create page: 0.238 seconds
