WAS DIRTYDOGZ JIMNY(SOFT TOP)
05 Dec 2011 11:16 - 07 Jan 2014 12:19 #27296 by dirtydogz
Replied by dirtydogz on topic Re: DIRTYDOGZ JIMNY
Fitted my roof spot light bar on the jimny at the weekend so here are some photos.
The bar is a mont blanc which came off my old fiat punto 5 door, and the spot light are ring from halfords.
Remove the plastic strip on the roof and the plastic cover on the inside and drill an 8mm hole in middle of the gutter slot, you can use an 8mm unistrut spring nut in the gutter slot.
Do not over tighten the nut and bolt has the roof as a double skin.
Use silicone sealant to seal the nuts and bolts.
You need to earth the spotlight to the car body.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 07 Jan 2014 12:19 by dirtydogz.
  • renard38
  • Visitor
  • Visitor
05 Dec 2011 18:32 #27318 by renard38
Replied by renard38 on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
good job ;)
  • myers647
  • Visitor
  • Visitor
07 Dec 2011 20:58 #27503 by myers647
Replied by myers647 on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
hi mate the spots look good does it fit in the gutter bit,I'v got the removable hard top one. I fitted a stick on light pod but i think im wanting a bar like yours to be honest. I just didnt think you could get a bar to fit a convertable.?
Thanks
James
10 Dec 2011 18:27 - 25 Jul 2013 21:40 #27802 by dirtydogz
Yes l know what you mean :unsure: but l had the roof rack so decided to have a go :dry: and if it didn't work, l only had to filling two holes in the gutter slot.:)
All wired up and working.
Ok roof light working with my main beam,85 trigger go from the relay to the ACC on the switch, power on the switch go to the red wire on the back of the headlight plug, l'm happy now at last.
I wired it up the same as in this relay picture, and just add a live from the relay fuse to the ground on the switch, to make the switch light up.
Last edit: 25 Jul 2013 21:40 by dirtydogz.
17 Dec 2011 10:02 - 08 Apr 2012 12:39 #28422 by dirtydogz
l had to take it ,there's not a lot of jimnys in high wycombe bucks :laugh:
Last edit: 08 Apr 2012 12:39 by dirtydogz.
17 Dec 2011 14:13 #28436 by Halford
B) light bar looks good
looks like a bit of lean on the blue Jimny :dry:
  • SOTA
  • Visitor
  • Visitor
17 Dec 2011 16:36 - 17 Dec 2011 16:36 #28456 by SOTA
Replied by SOTA on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
dirtydogz wrote:
Attachment not found
I hope you waited around for the blue jimny owner to do the double take on the height difference :laugh:
Last edit: 17 Dec 2011 16:36 by SOTA.
17 Dec 2011 19:37 #28481 by dirtydogz
lt was an old girl, she did have a good look and smiled at me.:blink:
Thank you, Halford I'm very happy with the way it turn out :P
  • r_ogilvy
  • Visitor
  • Visitor
17 Dec 2011 19:52 #28485 by r_ogilvy
Replied by r_ogilvy on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
dirtydogz wrote: Yes l know what you mean :unsure: but l had the roof rack so decided to have a go :dry: and if it didn't work, l only had to filling two holes in the gutter slot.:)
Ok roof light working with my main beam,85 trigger go to the red wire on the back of the headlight plug, l'm happy now at last.
got my spots switch done today, thanks :)
17 Dec 2011 20:08 #28488 by dirtydogz
That's ok mate glad to help.
We got there in the end,;)
  • Back in Black
  • Visitor
  • Visitor
29 Jan 2012 15:43 #32109 by Back in Black
Replied by Back in Black on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
There does seem to be a lot of Jimnys in High Wycombe - most of 'em shorter than ours......
Attachment IMG_0153.jpg not found
I have nearly as much lift as you -1.5 " spring and 2 " body spacers and bigger wheels.
Be interesting to park up next to you, or better still, either side of a "normal" Jimny....
Attachment IMG_0154.jpg not found
Both snaps taken on the same day, day after fitting the body lift.
My rear drivers side shock is shot, and if I'm going to replace it, I might try for a 3"inch lift kit (springs and shocks) as I presume the rest will break soon - once Jimnybits gets more stock.
Keep up the updates.......
29 Jan 2012 16:08 - 08 Apr 2012 12:23 #32112 by dirtydogz
Try Martin he has the 3" lift and it's in stock, and if you ring him you can go and pick it up from him in Woodley near Reading.
www.bigjimny.com/store/index.php/bigjimn...g-lift-kt/p_160.html
With the Jimnybits lift you pay £280+ VAT+PP so it work out about the same price,and with big jimny you get rough country shocks.
Last edit: 08 Apr 2012 12:23 by dirtydogz.
Time to create page: 0.193 seconds
