BigJimnyMeet 2024
WAS DIRTYDOGZ JIMNY(SOFT TOP)
- suzuki jimny fella
- Visitor
29 Jan 2012 21:39 #32158
by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
what the diffrents in rough county and pro comp witch are the best or are they pritty much the same shock
- Thank you received: 210
31 Jan 2012 20:12 - 18 Feb 2012 16:38 #32352
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
Sorry mate l don't know as l use pro comp ES1000 shock on my Jimny.
2002 JLX Soft Top
Last edit: 18 Feb 2012 16:38 by dirtydogz.
- Visitor
31 Jan 2012 20:46 #32362
es3000 i got lol so dont no
- bluejimny
- Visitor
31 Jan 2012 21:48 #32371
by bluejimny
Replied by bluejimny on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
rough country hydro 8000 similar damping rates to the ES3000's
rough country Nitro 9000 similar damping rates to the ES9000's (Quote from Dave at llama 4x4)
the ES1000's are more of an OE damping rate so are "less stiff" than the others but are more stiffer than STD jimny shocks tho.
05 Feb 2012 14:16 - 13 Apr 2014 17:50 #32740
by dirtydogz
Set off from High Wycombe at about 11.00 am, to pick up a set of radius arms fitted with superpro poly bushes, which l purchased for £100 on Sat 4 Feb from James (Nobby22) in Horsham W Sussex, around trip of 128 miles had a bit of a chat and a good look at James Jimny for about an hour, then had to leave to return home before the snow came.
Got home at about 4.00 pm and started on fitting the radius arms to my jimny had to drill two new hole for the vac pipes on the driver's side arm as james( Nobbys22) jimny was a later model, remove the off side arm first and fitted the nuts+bolts,then the near side, just finish as it started to snow so l had to give it a test drive.
Don't know how l put up with the steering, with out the ploy bushes it's like a new car.
2002 JLX Soft Top
2002 JLX Soft Top
Last edit: 13 Apr 2014 17:50 by dirtydogz.
- Nobby22
- Visitor
05 Feb 2012 15:35 #32750
by Nobby22
Replied by Nobby22 on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
So they went on ok then? I will put some pics up of my new ones at some point. Only got a few, as you know they didnt go on to easily so i wasnt in the mood for piccies . Is the steering better now?
I havnt had a go at the steering box on mine yet. You will have to remind me how to do it .
Almost forgot to ask, how was it drilling into the arms?
Nobby
Nobby
05 Feb 2012 16:49 - 08 Apr 2012 12:21 #32756
by dirtydogz
2002 JLX Soft Top
The drilling was easy just drill two hole threw the two little lugs on the middle of the arms and bolted on the vac pipes .
2002 JLX Soft Top
Last edit: 08 Apr 2012 12:21 by dirtydogz.
06 May 2012 16:08 - 06 May 2012 16:25 #39422
by dirtydogz
2002 JLX Soft Top
Not a lot done on the jimny this year, had to move the towbar electrics on to the bumper so it don't getting damaged off-roading.
Also replaced one of the tie-rod ends after getting some death wobble at 45 mph' so it's not always the king pins.
On my jimny it's been the wheels balancing and two tie-rod ends, 40,000 miles on the same king pins not to bad.
As you can see from the photo of the tie-rod ends, they have two different length threads so you will need to measure as in the photo, from the outside of the tie-rod end to the locking nut, so it fit in the same place as the old one on the steering bar.
Hope this helps.
Dirtydogz
Hope this helps.
Dirtydogz
2002 JLX Soft Top
Last edit: 06 May 2012 16:25 by dirtydogz.
10 Jun 2012 17:35 - 10 Jun 2012 17:38 #42132
by dirtydogz
2002 JLX Soft Top
Off to the rubbish tip today with all the wood panelling which was ripped out of the bathroom and the wife's surfboard, I've got to say the tow-bar and the trailer are the best mods i've fitted on to the jimny,that's if you can count the trailer as a mod
2002 JLX Soft Top
Last edit: 10 Jun 2012 17:38 by dirtydogz.
- TomDK
- Visitor
10 Jun 2012 17:38 #42133
by TomDK
Replied by TomDK on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
That's probably the smallest trailer I've ever seen
10 Jun 2012 17:51 - 10 Jun 2012 17:58 #42134
by dirtydogz
2002 JLX Soft Top
2002 JLX Soft Top
Last edit: 10 Jun 2012 17:58 by dirtydogz.
- goatboy
- Visitor
11 Jun 2012 07:48 #42154
by goatboy
Replied by goatboy on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
I just fitted the same towbar as you've got Barry.
Quite a nice bit of kit although I struggled a bit with fitting. Think my tie-down eyes have been used for towing something in the past and got a bit bent so they were in the way.
All on now (well part from the electrics which I was going to put exactly where you have)...
I thought you had some shackles on the towbar for recovery, or did I dream it?
Time to create page: 0.174 seconds
