WAS DIRTYDOGZ JIMNY(SOFT TOP)
- renard38
- Visitor
- Thank you received: 210
This was my first time at replacing the king pins, so I down loaded the (how to? guide) from this forum and printed it off, then I just got on with doing the job.
I even removed the bolts on the backing plate, so I could copper grease the bolts as you need to remove them if your are replace the wheel bearings at a later date (you can do the job with out removing the bolts and leave the back plate in place .)
I've only replaced the driver's side at the moment as that side was leaking oil and the weather was so bad, rain and snow.
The top bearing was OK but the lower one was a right mess some of the top of the bearing was missing so the bearing started to disintegrate, here are some photos to look at,so if yours are leaking oil this is the time to replace them.
The job takes about 2 hour and that was my first go at doing the kingpins, so if you have a go just take your time.
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- Nox
- Visitor
dirtydogz wrote: Decided to get a jack bracket from Russ at Jimnybits to fit my micro shovel on the back spare wheel bracket ready for the winter, so I don't have to have a wet carpet like the last two years.
Bracket cost £35.99 inc vat and pp.www.jimnybits.co.uk/shop/recovery/farm-j...racket/prod_572.html
Just some photos of it fitted.
Decided not to use the wheel spacer studs to fix the bracket, I just drilled two 6mm holes and bolted it to the spare wheel bracket,
www.screwfix.com/p/roughneck-micro-shaft...d-point-shovel/53829
That is so awesome!
Looking great DirtyDogz!
- Poyner111
- Visitor
I didn't notice any more noise after the roof bar was fitted,as you already know the soft top is not the quietest car to drive on the road.
2002 JLX Soft Top
- Poyner111
- Visitor
2) If the popers on your soft top get hard to undo with age, just use a little grease on the popers.
2002 JLX Soft Top
2002 JLX Soft Top
- Jimny_Aus
- Visitor
It's not that bad a job to do, the only hard bit of the job for me is fitting the starter motor, I hate that part.
Next job is a new gearbox mounting, had to use cable ties to hold it in place.
I'm starting find these jobs are get a little bit harder now I'm 61 years old.
If you need a new clutch kit for your JIMNY SOFT TOP the blue print part number is ADK 83024.or get the EXEDY clutch kit from the BIG JIMNY ONLINE SHOP
Goodbye for now.
2002 JLX Soft Top
2002 JLX Soft Top
- darthloachie
- Visitor
