BigJimnyMeet 2024
BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
- Thank you received: 82
11 Jul 2021 09:14 #236583
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
A good read on rust www.rust.co.uk/treating-rust-the-rustbuster-way
12 Jul 2021 21:10 - 12 Jul 2021 21:33 #236643
by Dirtbird
Last edit: 12 Jul 2021 21:33 by Dirtbird. Reason: SPELLING
- Thank you received: 1761
13 Jul 2021 03:20 #236647
Replied by Lambert on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
It's a lot easier when you have done it before!
15 Jul 2021 15:16 #236705
by Dirtbird
Now facing into the reconstruction cant decide what to do with the chassis after I clean it. I'll make up my mind soon enough.
24 Jul 2021 17:16 - 24 Jul 2021 17:18 #236929
by Dirtbird
Down to the Chassis, today boiling in the shed.
Going to need some advice on how to open and remove these black clips that hold the fuel and brake lines together I want to reuse them .
Last edit: 24 Jul 2021 17:18 by Dirtbird.
- Thank you received: 584
24 Jul 2021 17:49 #236931
by facade
Replied by facade on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
When I did my fuel & brake lines I had this idea that I could open them up and get the pipes out- they are too brittle. I ended up cutting the pipes into small sections and sliding them out one at a time (along the pipe, not across it). The clips did click over the new pipe though- mostly.
24 Jul 2021 18:23 #236932
by Dirtbird
Hey Facade thanks. Right my pipes are all ok as the Jinmy was driving up to 2 weeks ago. ok im trying to keep em but i heard you that they are brittle.
25 Jul 2021 06:26 #236942
by facade
I would change them if they are the ones in the last picture! They are easy to change with the body off, a right pain with it on.
Use copper alloy tubing, the only thing to watch is suzuki brake pipe fittings are short and threaded right to the ends, the more common type have no threads for the first 5mm, so only screw in a couple of turns.
26 Jul 2021 13:55 - 26 Jul 2021 13:59 #237000
by Dirtbird
So after about 19 days and not all full days, I have 2 Jimnys separated and a chassis about to go to the shot blaster and with a bit of luck start the reassembly end of the week.
Last edit: 26 Jul 2021 13:59 by Dirtbird.
26 Jul 2021 17:52 #237007
Excellent work, just demonstrates how effective determination is to getting a result.
26 Jul 2021 18:28 #237011
by Dirtbird
Thanks, Lambert.
- Godskitchen
- Visitor
27 Jul 2021 10:14 #237029
by Godskitchen
Replied by Godskitchen on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Excellent work, fair play. Where abouts in Ireland are you?
Time to create page: 0.168 seconds
