BigJimnyMeet 2024
BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
- Thank you received: 82
08 Sep 2021 07:36 #238330
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Dave you can see the buggy build creeping into my project.Oooh! Shiny!
- Thank you received: 583
08 Sep 2021 07:47 #238332
by facade
Replied by facade on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Looking good
08 Sep 2021 16:15 #238354
Replied by Riccy on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Love it
That chassis looks so good in galv
Keep up the excellent work
08 Sep 2021 19:53 #238365
by Dirtbird
Riccy telling myself to keep going and someday I'll be in Wales driving lanes with you guys.... thanks for the positive vibes guys...
08 Sep 2021 20:35 #238367
by Dirtbird
Loads of little fiddley bits today rear axle brake lines, tapping some holes as the galv protect didn't quite do the job. Got the 4WD tranfer box in and working on the vacuum lines
08 Sep 2021 22:35 - 08 Sep 2021 22:40 #238371
by Dirtbird
Ok was a bit browned off after I connected the vacuum pipes to the hubs this evening. (Sticking with the vacuum for the moment until I get the funds for mechanical free wheeling hubs) . To be precise I thought the black plastic pipe armor/shield looked a bit tatty at the ends see below.
So I took them off again and hit them with some heat shrink.
Ok, it's not super flash but to me, it's a bit tidier. To be fair a lot of the builders here go to the next level and that's what influenced my little tity up job.
Last edit: 08 Sep 2021 22:40 by Dirtbird.
09 Sep 2021 14:33 #238396
by Dirtbird
10 Sep 2021 19:08 #238437
by Dirtbird
Ok the 2004 M13A and 1999 G13BB power steering boxes are not the same , the banjo fittings on the G13 are smaller than the M13. Had to swap pumps this evening.
Also, the rad brackets on the M13A don't match the holes perfectly on the G13 chassis had to clean the G13ones and paint em will fit tomorrow.
- Thank you received: 1759
11 Sep 2021 03:38 #238449
Replied by Lambert on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
A few minor inconveniences along the way to add interest and stop you getting bored!
11 Sep 2021 07:44 #238454
by Dirtbird
It's funny that there are variations in bolt holes etc given it's changed very little. there are only 5 years between the two jimnys on this project.
11 Sep 2021 19:17 #238484
by Dirtbird
Ok Engine in and Gearbox, Clutch kit ordered and will fit before I go any further. Rear engine mount shot so need to buy a new one and stick in the brake shoes. I think the M13A engine and gearbox is about 10mm longer than the G13BB because when I dropped in the engine and gearbox the rear engine mount didn't line up with the chassis by 10mm.
12 Sep 2021 14:57 - 12 Sep 2021 14:57 #238522
by Dirtbird
Power steering installed and all cleaned. Rad Brackets added. Rear engine mounts repaired with tiger mastic.
Last edit: 12 Sep 2021 14:57 by Dirtbird.
Time to create page: 0.279 seconds
