BigJimnyMeet 2024
BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
- Thank you received: 584
01 Sep 2021 10:30 #238106
by facade
Replied by facade on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
A hundred kilos of zinc on a chassis!
I find that a bit hard to believe, if it were 1mm thick, that would be 14 sq metres coverage, You sure it was 100kg, not 10? or have they filled it solid with zinc?
You will have the car overweight if you carry 4 people with 100kg extra weight on the chassis
- Roger Fairclough
- Thank you received: 194
01 Sep 2021 10:43 #238107
by Roger Fairclough
Replied by Roger Fairclough on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
I am going out so I will leave it to someone else to work it out but to start them off, the zinc will have a thickness of 0.007-9" (7-9 thou of an inch). When I had my Triumph GT6 chassis galvanized, I could still pick it up!
Roger
Roger
- Roger Fairclough
01 Sep 2021 14:01 #238114
by Roger Fairclough
I have done the maths and I reckon we are looking at 20lbs.
Roger
Roger
- Thank you received: 82
01 Sep 2021 22:22 #238137
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
01 Sep 2021 22:34 #238138
by Dirtbird
02 Sep 2021 08:04 #238149
by facade
I think they bill you for 100kgs minimum per job, and rub their hands with glee when you only use 10. You are paying for the time and trouble rather than the zinc. They weigh the job before and after and would charge for any zinc over the 100kg.
You will need to run a tap through any threaded holes now to make sure they are clear.
Next time, find a way to bolt 5 chassis together in a block and get it done as 1 part within the 100kg job
02 Sep 2021 22:29 #238171
by Dirtbird
I used Galv protect on the threaded holes
05 Sep 2021 17:45 #238247
by Dirtbird
A slow week on the Jimny hope I can get all the axels, shafts and engine, gearboxes in this week .
07 Sep 2021 20:00 - 07 Sep 2021 20:08 #238322
by Dirtbird
Last edit: 07 Sep 2021 20:08 by Dirtbird.
- Roger Fairclough
07 Sep 2021 21:08 #238325
by Roger Fairclough
Just a point Dirtbird. The picture that shows the position of a king pin may possibly be indicating raised threads. If so I recommend removing the excess threads with a chamfer bit. If, on the other hand it is just sealant, ignore what I have just written.
Roger
Roger
07 Sep 2021 21:56 #238326
by Dirtbird
Rodger sealant
- Thank you received: 923
08 Sep 2021 05:40 #238327
Replied by X8GGY on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Oooh! Shiny!
Time to create page: 0.244 seconds
