BigJimnyMeet 2024
BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
- Thank you received: 82
15 Sep 2021 19:41 - 19 Sep 2021 08:35 #238650
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Ok differential breather kit my recipe.
So going to run the entire vent system through one line .
Using 1/8 BPS 6 mm pipe push fittings
2 elbows
2 nipples
3 tees
and a push fit nipple with filter attached. Which ill run up the snorkle .
Used thisto tap the holes .
Transfer box
Gearbox you can remove the factory nipple wih a pliers
Nipple installed in Gear box
Diffs are straight forward with the 1/8 BPS tap making thread with no additional drilling .
2 elbows
2 nipples
3 tees
Transfer box
Last edit: 19 Sep 2021 08:35 by Dirtbird.
19 Sep 2021 07:05 #238772
by Dirtbird
Got the fuel line in and the brake line as well. In 2004 it's a single brake line and in 1999 it's a single line that branches off at the rear into two lines. I had rounded the brake line nuts in the two-way splitter under the driver-side floor area so I needed to get them out and make up a new line.
Friday night went online and order a flaring kit, some copper line, and some brake nuts from Halfords and picked up Saturday morning. Really important to BUY A PIPE CUTTER.
19 Sep 2021 07:08 - 19 Sep 2021 07:13 #238773
by Dirtbird
I ended up having to scavenge brake line nuts off the other lines because there's a small difference between the Halfords nuts and the Jimny nuts. Halfords brake line nut notice the 3 mm at the end of the nut
This is the jimny nut and that 3 mm makes all the difference
Other wise the flaring tool is easy to use and does the job all in all not bad for €30 and the copper pipe and nuts another €20 so affordable and a good set of tools to have .
Last edit: 19 Sep 2021 07:13 by Dirtbird.
19 Sep 2021 07:17 #238774
by Dirtbird
The other thing I forgot to mention was I cleaned the lines with a wire wheel, and sandpaper and then sprayed them with rattle can zinc paint.
21 Sep 2021 22:27 #238869
by Dirtbird
To any of you who have changed a clutch from the floor, I salute you. I was going to not bother but now I'm glad I changed it while the body was off. Even with the body off the bolts under the starter motor were tough.
15 Oct 2021 19:45 #239437
by Dirtbird
Work has me getting up going out coming home getting up going out coming home getting up................. the last couple of weeks however hoping to put the body on this weekend.
Made a new brake line and did the bolts that hold the hand brake cable onto the cross member plus found a braided stainless steel brake hose.
13 Nov 2021 18:42 #240075
by Dirtbird
13 Dec 2021 21:23 #240625
by Dirtbird
Well, a dose of Covid fairly knocked the sheet out of me. Back at it again today got the body on.Would like to get it running by Christmas .Hope ye are all well.
- Thank you received: 1761
14 Dec 2021 04:16 #240631
Replied by Lambert on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Glad to hear you're back on your feet.
06 Jan 2022 21:50 #240946
by Dirtbird
06 Jan 2022 21:53 - 06 Jan 2022 21:55 #240947
by Dirtbird
Also cannot remember where these go? The two black females, are joint together and look like the letter M
The wire is long enough to go back to the fuse box beside the battery.
Last edit: 06 Jan 2022 21:55 by Dirtbird.
- Thank you received: 552
07 Jan 2022 07:57 #240953
by Scimike
Replied by Scimike on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
I believe the black M connector is the horn.
Easy to check with multimeter before you connect.
Mike
Mike
Time to create page: 0.287 seconds
