BigJimnyMeet 2024
BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
- Thank you received: 82
27 Jul 2021 16:02 #237040
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Sent you a message Godskitchen
28 Jul 2021 16:54 - 28 Jul 2021 18:42 #237095
by Dirtbird
I have some more welding to do but couldn't get into the headspace today so I said I clean up the engine bay, clean up some spot rust and get some rust converter onto them.
Battery tray, I can't take it off so going to do the best I can with a 4 inch and 3-inch wire wheel brush cup.
Once it's cleaned down going to wash the engine bay with some washing liquid and warm water let that dry. Then hit it with KRUST the Hammerite rust converter let it dry and hand paint the engine bay after a rub down with sandpaper and a wash down.
Steering link arm before wire wheel cup brush
This is the gizmo
This is the gizmo
Last edit: 28 Jul 2021 18:42 by Dirtbird.
30 Jul 2021 17:39 #237165
by Dirtbird
06 Aug 2021 19:39 - 06 Aug 2021 19:44 #237349
by Dirtbird
Progress
Going to weld the boot space where the jack is kept. Remove spot rust, rust converter on the spots, and spray with LOWES white and then stone chip protection to the areas as previous areas.
Last edit: 06 Aug 2021 19:44 by Dirtbird.
- Thank you received: 1761
06 Aug 2021 20:09 #237352
Replied by Lambert on topic BODY SWAP a 2004 M13A onto a 1999 G13BB chassis
Welding generally working on cars is so much better when you are comfortable, which with the body off looks easy.
07 Aug 2021 00:19 #237355
by Dirtbird
Finding the welding tough as im using flux core 0.9 wire . Ive to be really quick with the stitches and it's just about doable with the body off cannot imagine how people do it with the body on .Welding generally working on cars is so much better when you are comfortable, which with the body off looks easy.
08 Aug 2021 11:26 #237394
by Dirtbird
Tipperary Godskitchen
08 Aug 2021 19:56 #237415
by Dirtbird
17 Aug 2021 16:36 #237668
by Dirtbird
Used this to protect the threaded captive nuts etc .
On the weight bridge
turns out there going to blast it again and will touch up any areas that need it so despite my best efforts they dont want it to leave the plant in less than 100% galvanized. He also told me they bulk bath chassis over the weekend in acid to ensure the internals get well eaten.
We will see on Monday?
17 Aug 2021 16:48 #237671
48h in an acid bath? It's certainly going to be clean. Or dissolved!
18 Aug 2021 21:48 #237703
by Dirtbird
Yeah, Lambert ...I was thinking that they won't shot blast it and leave it in the acid and charge me for both. ?
Lets see.eh.
Lets see.eh.
20 Aug 2021 23:41 - 20 Aug 2021 23:43 #237751
by Dirtbird
Last edit: 20 Aug 2021 23:43 by Dirtbird.
Time to create page: 0.514 seconds
