Fitting a rock lobster (SJ) transfer box in a Jimny...
16 Jul 2020 07:23 #225149 by zukebob
It was such a well thought out and presented question that I didn't want to distract from it. :)
The following user(s) said Thank You: X8GGY, Lambert
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
16 Jul 2020 07:29 #225150 by X8GGY
Yes, Lambert makes a good point :)
I’m thinking brackets linked to the spine (which protects the transfer box from stresses) and a skid plate under it but not integral to it then?
16 Jul 2020 07:52 #225152 by zukebob
A separate skid plate would be best but only if you can dedicate enough room to have a sufficient gap between it and the transfer cradle. It shouldn't require too much space unless you really let the beast out when you drive. You could just provide enough to help ensure that any deflection doesn't still cause impact to the cradle. You know more about the ground clearance to an SJ transfer than I do so it would really go back to your opinion on space.
16 Jul 2020 07:57 #225153 by zukebob
If you don't think having a skid plate below your mount is a good idea, I think you can make a couple of simple additions to your cradle that should help.
16 Jul 2020 12:17 #225162 by Lambert
Sorry if I planted a monkey wrench in your plans Dave. It's the reason I was so keen to get the separate belly plate for Dreadnought even with the steel case brackets. Now it going to be a significant day ending impact that does for my transfer rather than just a bit of a smack on a stone.
16 Jul 2020 23:48 - 16 Jul 2020 23:52 #225197 by yakuza
Several competition SJ413 based cars in the Norwegian trial series have a braced and cradled SJ transfer box. Design like the ring that hooks into the bolts and Welded to a cradle connecting the mountings.
Some cars got 200hp volvo turbo engine, and 35" tyres and toyota axles.
Very few has had torque related problems as far as I know. The cars get bashed and crushed of course until something breaks and it all does, but still the 4.16:1 case remain in use for many.
Last edit: 16 Jul 2020 23:52 by yakuza.
Time to create page: 0.186 seconds
