Fitting a rock lobster (SJ) transfer box in a Jimny...
- X8GGY
04 Jul 2020 15:29 - 04 Jul 2020 15:47 #224494
Fitting a rock lobster (SJ) transfer box in a Jimny... was created by X8GGY
Sat in the shop contemplating...
I’ve got a rock lobster transfer box as a side project, just in case the standard-ish (diffs changed) gearing doesn’t work out for me in the buggy project...
I’ve just ordered a JimnyBits conversion spacer -
So that - in theory - I can fit a standard Jimny rear propshaft...
And I’m in the process of buying a Jimny standard transfer box to put on the bench and attach standard mounting brackets so that I can have a reference / pattern...
So, my question... has anyone ever fitted an SJ / rocklobster transfer box in this way and used readily available standard Jimny propshafts, rather than having to rely on old / obsolete SJ parts...?
Hence wanting the standard transfer box to experiment in getting the SJ transfer box to sit in the same place as the Jimny transfer box...
Last edit: 04 Jul 2020 15:47 by X8GGY.
04 Jul 2020 15:46 #224496
Replied by mlines on topic Re:Fitting a rock lobster (Samurai) transfer box in a Jimny...
Based on recent experience, using a prop shaft company to adjust and then balance props was quite competitive to buying and refurbishing SJ props, and they are then the correct length rather than "close"X8GGY wrote: Sat in the shop contemplating...
- X8GGY
04 Jul 2020 15:57 #224497
Replied by X8GGY on topic Re:Fitting a rock lobster (Samurai) transfer box in a Jimny...
Thanks Martin...
What props did you have adjusted? The standard Jimny ones?
04 Jul 2020 18:22 #224500
SJ ones.
Although the mounts were "designed" for SJ props, they still needed quite a bit of adjustment for a proper fit.
- X8GGY
04 Jul 2020 19:09 - 04 Jul 2020 19:11 #224506
Ah, ok, thanks...
That's what mate Brett (Maverick on here) has done too...
Last edit: 04 Jul 2020 19:11 by X8GGY.
04 Jul 2020 19:24 #224507
The mounts on mine are probably not representative of the current designs. They were a very early prototype from ORA in probably 2007 so I expect there was more "tuning" work to be done in terms of positioning.
Time to create page: 0.300 seconds
