BigJimmy Store uses cookies. For more detailed information about these cookies please see our privacy policy. Please accept to continue or block all non-essential cookies.
£0.00
Your Basket
Your basket is empty.
Added to Basket
88287b63d19fcf47bea09e89c8010602
£ GBP
Login
Register
Advanced Search
Please enter a search keyword
Advanced Search
Shop by Category
Shop by Category
SJ/Sierra - Gen2
SJ/Sierra - Gen2
Parts & Service
Parts & Service
Bearings and Seals
Engine Parts
Steering, Axles & Bushes
Body Panels and Parts
Nuts, Bolts and Fittings
Hardware and Body
Accessories
Jimny - Gen3
Jimny - Gen3
Parts & Service
Parts & Service
Bearings and Seals
Filters and Cooling
Engine Parts
Engine Parts
Engine Parts
Sensors
Belts
Braking/Clutch parts
Electrical
Body panels and parts
Suspension
Hardware & Body
Modification Parts
Accessories
Promotional
Jimny - Gen4
Jimny - Gen4
Parts & Service
Parts & Service
Electrical
Brakes & Clutch Parts
Engine Parts
Bearings and Seals
Filters and Cooling
Accessories - 2019+
Suspension
Modification parts
Modification parts
LED Bulbs
Other Suzuki Models
Events
Back
Home
Jimny - Gen4
JavaScript is required by this website. Please enable this in your browser settings.
Jimny - Gen4
Parts for the Generation 4 Jimny - 2019 onwards
Parts & Service
Accessories - 2019+
Suspension
Modification parts
Sort by
-- Please Select --
Name (Z-A)
Name (A-Z)
Date Added (Newest First)
Date Added (Oldest First)
Price (High-Low)
Price (Low-High)
10mm Square Oil service Socket
This is the CORRECT socket to use for removing the Gearbox, Transfer Box and Differential oil filler and drain plugs. …
£4.00
Add to Basket
£4.00
Add to Basket
45mm Lift Kit - Pedders - Gen4
Pedders 1.75 Inch (45mm) Suspension Lift Kit. Suzuki Jimny Improved looks and ground clearance. Are you looking to…
£725.00
Add to Basket
£725.00
Add to Basket
Air Filter - Genuine Suzuki (Gen4)
A genuine SUZUKI replacement top quality Air Filter. For K15 Gen4 Jimnys only Note: Picture does not show exac…
£30.00
Add to Basket
£30.00
Add to Basket
Aircon/Pollen Filter
Standard pollen filter for Gen4 Jimny This is a genuine filter, it is the one that goes behind the glovebox.
£20.36
Add to Basket
£20.36
Add to Basket
Aircon/Pollen Filter (Anti-allergen - Gen4)
Upgraded anti-allergen filter for Gen4 Jimny, this is a Suzuki Accessory This is a genuine filter, it is the one tha…
£26.67
Add to Basket
Aircon/Pollen Filter…
£26.67
Add to Basket
Brake Banjo Bolts
Pair of Banjo bolts complete with a pair of copper crush washers Essential when working on the calipers to get a good…
£3.50
Add to Basket
Brake Banjo Bolts
£3.50
Add to Basket
Breather Valve Kit
Genuine Suzuki breather valve kit This is the pop-up valve on top of the differential. Perhaps you have damaged yours…
£8.82
Add to Basket
Breather Valve Kit
£8.82
Add to Basket
Caliper Fitting Kit (VENTED DISK)
Kit containing caliper fittings for the vented disk caliper on a Suzuki Jimny. Note that this does not fit standard UK …
£13.00
Add to Basket
£13.00
Add to Basket
Crankshaft Woodruff Key
Woodruff key used on both G13, M13 engines including VVT and K15 (Petrol - Gen4)
£3.80
Add to Basket
£3.80
Add to Basket
Dashboard panel
Driver side (UK) lower dashboard panel (Please enquire about overseas, ie Left hand drive versions) This is the panel…
£24.72
Add to Basket
Dashboard panel
£24.72
Add to Basket
Differential Drain Gasket
The gasket (or washer/oil seal) that seals the Differential DRAIN plug on Gen4 (JB74) Jimnys. Notes: This gask…
£3.32
Add to Basket
£3.32
Add to Basket
Differential Filler Gasket
The gasket (or washer/oil seal) that seals the Differential FILLER plug on Gen3 (JB33/JB43) Jimnys and Gen4 Jimny (JB64…
£3.32
Add to Basket
£3.32
Add to Basket
6 per page
12 per page
24 per page
48 per page
96 per page
1
2
3
Next
178
Featured Product
£3.32
Best Sellers
Kingpin Bearing Kit (Premium - Koyo)
£24.50
KingPin Shim Kit
£3.50
Hub Nut Tool
£41.00
Swivel/Knuckle Seal (Suzuki)
£32.08
Suzuki Jimny Wobble Kit
£92.68
Kingpin Bearings (Koyo) with Swivel Seal Kit (Premium Seal)
£55.00
Waterproof Grease
£12.00
CV Joint (Type 2)
£42.00
Front Axle Oil Seal
£3.00
Rear Speaker Mounting Kit
£62.00
Top
eCommerce by
CubeCart
