45mm Lift Kit - Pedders - Gen4
  • Click to enlarge
£725.00
Product Information
Specification
Pedders 1.75 Inch (45mm) Suspension Lift Kit. Suzuki Jimny
Improved looks and ground clearance.
Are you looking to raise your Jimny?
Then Pedders Suspension have the solution for you.
This kit features our excellent Pedders TrakRyder Foam Cell shocks, front & rear coil springs, and the necessary parts to deal brake hose and headlight switch changes.
This kit is our Premium Lift Kit, and is designed primarily to raise the vehicle and improve ground clearance.
This kit will raise the vehicle by approx. 50mm allowing better ground clearance and improved looks. Articulation in off road conditions is achieved through the use of longer travel shocks. This kit can be used to accommodate larger tyres. The dimensions quoted assume a standard vehicle.
These components replace the original items. No other modifications to the vehicle are necessary. After fitting we strongly recommend a wheel alignment is carried out for optimum performance of your vehicle.
Included in the kit are longer brake hoses for the rear and the necessary parts to allow correct operation of the headlight levelling system. NOTE, it is NOT possible to simply extend the bracketry or similar on this vehicle if using longer shocks. Doing so will result in the headlight levelling switch breaking under full suspension compression. The parts included in our kit overcome this issue.
Still not sure this is the correct kit for you? Have further questions? Then please do get in touch with one of our team here at Pedders who will be able to assist you.
Key features
  • 1.75 Inch Lift Kit
  • Increased Off-Road Ground Clearance
  • Sintered Iron Piston Shocks with Large 35mm Bore
  • Premium Grade Steel Coils
  • All backed by Pedders 2 year / 40,000km warranty
Vehicle Height Information
Front: 45mm higher than standard
Rear: 45mm higher than standard
NOTE: THE DELIVERY TIME ON THESE CAN VARY. USUALLY IT IS WITHIN 2 DAYS BUT SOMETIMES THE STOCK HAS TO COME FROM EUROPE
Product Code803376
ManufacturerPedders
ConditionNew
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
