Caliper Fitting Kit (VENTED DISK)
  • Click to enlarge
  • Click to enlarge
£13.00
Product Information
Specification
Kit containing caliper fittings for the vented disk caliper on a Suzuki Jimny. Note that this does not fit standard UK Jimnys, it is for vented disk conversions only.
This kit is for one caliper.
It contains:
  • Pair of high tensile bolts
  • Pair of caliper sliders
  • Caliper rubber seals
  • Sachet of slider grease
These are the parts that typically corrode and stick, causing your brakes to stick on. The rubber seals in particular need care and should only use the special grease to stop the rubber being affected by oils.
NOTE: As this is not a standard UK Jimny fitment but is for the vented disk conversion, this is NOT a stock item so allow extra days for delivery
Product CodeBCF1324 (VENTED DISK)
ConditionNew
Weight0.145Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
