Differential Drain Gasket
  • Click to enlarge
  • Click to enlarge
£2.11
Product Information
Specification
The gasket (or washer/oil seal) that seals the Differential DRAIN plug on Gen4 (JB74) Jimnys.
Notes:
  • This gasket is a crush gasket, therefore should only be used once and replaced, therefore if you are changing the diff oil in your Gen4 Jimny you will need one of these,
  • This only fits the Gen4 Jimny, if you are wondering whether you have a Gen3 or Gen4 then the fact you are wondering means its a Gen3 :)
Product Code09168-12002
ManufacturerSuzuki
ConditionNew
Weight0.01Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
