Your basket is empty.
Tap to enlarge
This is an aftermarket drive belt and is know to fit M13AA engines with PAS (NO AIRCON)
Note: this is an aftermarket belt in a standard size that is close to the original Suzuki size but not exact - it is a couple of mm smaller. This is typical of aftermarket belts from Motor factors where they only stock a set number of sizes.
A description of the belts used on a Suzuki Jimny can be found at https://www.bigjimny.com/mediawiki/index.php/Drive_Belts
eCommerce by CubeCart
