Rear Wheel Bearing Kit (ABS - Gen3)
  • Click to enlarge
£83.00
Product Information
Specification
A superior Rear wheel bearing kit complete with ABS Bearing Retainer/Sensor and Oil Seal.
Yes - its the ABS version AND it includes the sensor ring.
Includes:
Koyo Bearing (These are the EXACT bearings that Suzuki would suppy, they supply Koyo as standard)
ABS Bearing Retainer INCLUDING ABS Ring (so you do not have to remove the old ring by heating it)
Generic Metal case double lipped Oil Seal Size: 48 x 62 x 9 R6  - SEE NOTE BELOW
This kit contains EVERYTHING you need, including the Bearing Retainer Ring.
Fits: All Jimnys WITH ABS
At this price you could keep one on the garage shelf ready for when the inevitable happens! Does your rear wheel look like this!!
NOTE: This is the kit for the 1998-2018 Jimny (Gen3). Suzuki have changed the seal for the new 2018+ Jimny to a tighter fit seal  46 x 62 x 9 R6. I believe you can fit the Gen4 kit to a Gen3 Jimny if you want a tighter fit seal. See the "RELATED PRODUCTS" section if you wish to purchase the Gen4 kit instead
Click HERE for instructions on installation (note: instructions are for non-abs version)
Product CodeGen3 ABS Kit
ManufacturerBigJimny
ConditionNew
Weight0.801Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
