Radius Arm Bolt
Radius Arm Bolt
Tap to enlarge
£2.75
Product Information
Specification
When you change your Radius Arms then the inevitable will happen. You will find one of the bolts has siezed or cold welded itself into the Bush.
You WILL end up cutting one off. Therefore make sure you have the correct parts to hand when you start.
This set consists of a High Tensile Bolt (M12 x 100mm METRIC FINE), Nyloc nut and washers
Just by buying these should ensure that yours undo without any problems!
Please note that these are a standard 100mm in length whilst the Suzuki originals come in a variety of lengths up to 100mm.
These are supplied with washers
This set will do ONE Radius Arm BUSH.
Product CodeRADIUSARMBOLT
ManufacturerBigJimny
ConditionNew
Weight0.15kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
