JIS Screwdriver set
JIS Screwdriver set
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
Product Information
Specification
A four piece JIS (Japanese Industrial Standard) Screwdriver set.
The screw heads in your SJ/Jimny are not necessarily Philips, despite how they may look. They are likely to be JIS. If you use the incorrect screwdriver you will strip out the head.
This is the correct JIS fit screwdriver set, It consists of 4 screwdrivers.
  • suitable for cross-slot screws according to the Japanese industrial standard (JIS)
  • these special screw heads have different dimensions and angles than a PH screw
  • a standard PH screwdriver will wind out of the screw head if too much torque is applied
  • suitable for Japanese products as well as for vehicle and motorcycles
  • special handles maximize the torque from the hand to the screw
  • with cross hole for hanging
  • magnetized tips
  • anti-slip ergonomically formed handle
Contents:
  • 1 x JIS 1 x 75 mm
  • 1 x JIS 2 x 38 mm
  • 1 x JIS 2 x 100 mm
  • 1 x JIS 3 x 150 mm
Material: Chrome Vanadium Steel
Surface finish: Satin finish, matt
Handle type: 2 component handle
Suitable for wall hanging: Yes
Product Code70049-JIS
ManufacturerBigJimny
ConditionNew
Weight0.8Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
