The mounting stud for the fan to the water pump.
These are NOT included with a new water pump for some reason, therefore you have to remove the old ones and transfer them to the new pump. During this process it is easy to damage them.
The price is for a single stud, you may require up to 4 depending on the success of removing the old ones.
YOU DO NOT NEED THESE IF YOU ARE BUYING THE VISCOUS HUB UNIT AS THEY ARE INCLUDED IN THAT PRODUCT
