CV Joint (Type 1) - Unbranded
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
£22.00
Product Information
Specification
MAKE SURE YOU PURCHASE THE CORRECT TYPE
Suzuki only sell the full drive shaft as a complete unit.
This is a replacement for the 6 balls, 26 external splines and 19 internal splines CV
The joint comes with a replacement snap ring.
Depending on the source (it varies for these unbranded items) it will also contain a grease sachet and rubber boot. The boot is not used in the Jimny application (well I have not got it to fit!)
Notes:
1. This is the joint only, the full Suzuki number refers to the complete Driveshaft assembly.
2. This unit is a 6 ball CV - unbranded
3. Some of the pictures show a used item, clearly I will supply a brand new one smiley
4. The Suzuki part numbers for the complete shaft assemblies inlcuding the CV joint are:
  • 44102-81A00 (left side)
  • 44101-81A00 (right side)
Instructions on replacement are here: https://www.bigjimny.com/mediawiki/index.php/CV_joint_replacement
The table below is for GENERAL GUIDANCE ONLY - PLEASE CHECK YOUR SPECIFIC NEEDS BEFORE ORDERING
Country of ManufactureEngineVIN NumberCV Type
Japan (JSA)G13BALLType 1
Spain (VSE)G13BALLType 2
AllM13Aup to 00186627Type 1
AllM13Afrom 00186627Type 2
Product CodeUnbranded CV1
ManufacturerBigJimny
ConditionNew
Weight1.49Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
