Clutch Cable - Aftermarket
  • Click to enlarge
  • Click to enlarge
Product Information
Specification
An aftermarket clutch cable (23710-81A0V) as Suzuki have discontinued the original!
If your clutch feels heavy or rough when pressed then this is the likely cause. The nylon liner within the cable wears through and makes it rough to operate
Note: there are THREE (just discovered another one!) types of clutch cable fitted to Jimnys. Please check which type you need, if in doubt contact the store. See the pictures above for more details.
IN THE PICTURE SHOWING THE TWO TYPES OF CABLE END, THIS IS THE BOTTOM ONE B UT BE CAREFUL, THE NEWLY DISCOVERED TYPE 3 CABLE HAS SIMILAR ENDS
If you are looking to buy a Type 2 please contact us with your VIN number to see if in fact you need a Type 3 cable.
These are for UK cars (Right Hand Drive)
Product Code23710-81A0V or 23710-81A00 Equivalent
ManufacturerBigJimny
ConditionNew
Weight0.55Kg
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
