Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
- Morpheus87
25 Nov 2020 03:08 #230372
by Morpheus87
Replied by Morpheus87 on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Same problem on my Jimny 2019. It was repaired under warranty, but returned later with minor intensity. Problem was transfer case chain
- Groenewald
- Premium Member
- Thank you received: 14
25 Nov 2020 06:32 #230376
by Groenewald
Replied by Groenewald on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I also have it.
Sounds more like a heavy mechanical whine.
I have a reasonably steep driveway and hear it when I drive up in first gear. The sound is harder when I give it more petrol...
25 Nov 2020 06:39 #230377
by Pspies
Replied by Pspies on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
So 6 weeks later, the parts have finally arrived. Dropped off the Jimny yesterday. Will get it back in 4 days time.
I'll update once I get it back.
- Morpheus87
27 Nov 2020 09:51 #230432
by Morpheus87
Check for oil leaks from transfer case after replacement. Mine had some
30 Nov 2020 17:17 #230530
by Pspies
So. It’s been 4 days and about 200km of stop start driving around town.
All quiet. In fact driving in general is much quieter and smoother. The transfer chain was clearly making more noise than just the grrr sound at take off.
No oil leeks. (I see Suzuki shipped a plug and nut as part of the repair kit).
Attached is a copy of the workshop repair doc and parts list.
Touch wood this is the end.
- coellobranco
- Thank you received: 2
22 Jan 2021 13:13 #232067
by coellobranco
Replied by coellobranco on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Same problem on Jimny from 2019, suzuki approved repair. I am waiting for the parts.
- Thank you received: 66
22 Jan 2021 13:24 #232068
by lightning
Replied by lightning on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
No issues with our 2020 SZ5
02 Feb 2021 07:23 #232420
by vagepap
Replied by vagepap on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Just sharing my experience. I had mine back at the dealer to replace the noisy parts. I have done 700km since. The noise is completely gone. Also generally the Jimny is a lot quieter now. It seems that a lot of cruising noise was also coming from the transfer gearbox, like a whining noise that now has been reduced significantly.
02 Feb 2021 20:28 - 02 Feb 2021 20:28 #232429
by lightning
What mileage is yours on? Ours is silent, but it's only done 3,500
Although with over two years left on the warranty l am not unduly worried.
Last edit: 02 Feb 2021 20:28 by lightning.
03 Feb 2021 17:12 - 03 Feb 2021 17:15 #232447
by vagepap
8000km on the clock. The noise started roughly when I had 4000km, so close to your mileage as you are on miles.
But it was generally noisy ( regarding the cruising noise) from day one.
The weird noise that appears when you try to pull hard on the first gear, e.g. when you try to ascend a hill, drove me to the dealer and by solving that issue the Jimny became also generally quieter.
Last edit: 03 Feb 2021 17:15 by vagepap.
- ITAYKOREN76
25 Apr 2021 09:40 #234705
by ITAYKOREN76
Replied by ITAYKOREN76 on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
HELLO
is it manual or auto ?
- coellobranco
07 May 2021 14:48 #234913
by coellobranco
I have changed the chain and it still makes noise. Now I have changed the transfer for a new one and makes noise too ...
Time to create page: 0.276 seconds
