Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
- ITAYKOREN76
10 May 2021 08:08 #234944
by ITAYKOREN76
is it automatic ?
Replied by ITAYKOREN76 on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
is it automatic ?
10 May 2021 09:31 #234945
Replied by Soeley on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
As far as I know, it's only the Manual that is affected? Someone else might be able to confirm though?
- coellobranco
10 May 2021 12:37 #234946
by coellobranco
Replied by coellobranco on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Manual...
watch this video:
watch this video:
10 May 2021 14:53 #234948
by lightning
Replied by lightning on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Our 2020 Jimny is a manual and never had any untoward noises from the transmission.
12 May 2021 12:51 #234996
by fordem
Replied by fordem on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Our 2021 is manual and has the noise.
- elliotAs
21 Jul 2021 02:47 #236842
by elliotAs
Replied by elliotAs on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
I have a 2021 model with same noise. Found this below on the German forum. I will mention it on my 1000km check.
"The Service Bulletin Q-AG6-004 of May 22nd, 2019 describes the " Optional spare parts information to reduce the noise from the transfer case when starting up ": Problem Description:When starting off in 1st gear, noises can be heard from the transfer case at approx. 2,000 rpm due to vibrations in the drive chain. Remedial measures:An optional spare parts set has been introduced to reduce noise from the VTG by optimizing friction and damping vibrations in the drive chain. ET information:Drive Chains - Set # 29200-78R00 29951-83050 flange nut (2)29941-77R00 screw retaining spring (2)29946-80051 oil drain plug (1)29945-80051 oil filler plug (1) 09106-06139 Screw, gear lever knob (1)09117-08079 PTO shaft screw (1)"
