Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
  • Foxtrot
18 Aug 2020 10:13 #226891 by Foxtrot
Its probably not related however the outcome may help. I had a 2007 G3 with a grinding noise from new, they tried to rebuild the transfer box but it was still doing it. They then put in a new box under warranty which cured it.
18 Aug 2020 10:17 - 18 Aug 2020 10:25 #226893 by mlines
Based on the diagrams from the electronically operated gen3 and the gen4 they look all but identical (apart from the mechanical lever on the Gen4 and the electric actuator on the Gen3)
Last edit: 18 Aug 2020 10:25 by mlines.
The following user(s) said Thank You: Scimike
18 Aug 2020 12:14 #226900 by Scimike
Thanks Martin,
If they are identical it makes me think the noise is not the transfer box itself. Possible installation issue, hitting bodywork, resonance?
Difficult to know unless we can identify what they do to fix or reduce it
21 Aug 2020 19:04 #227111 by lightning
Spigot bush?
Get the same intermittent noise on Defenders
  • Andy2640
22 Aug 2020 12:33 #227167 by Andy2640
Guys, I have had the 'Micro-grind' noise now for over 1 year. This is my thoughts:
It rarely makes this "Zizz" noise. As reported by others, it is commonly heard in 1st gear whilst pulling away.
Over the year it HAS NOT gotten any worst.
The service bulletin fix, seems to solve the issue with some, and not others. Which is odd.
Im certainly not a mechanic, but since the problem hasnt gotten worst, I am not at all worried about it.
So i now wonder whether this is something i am going ro address with the dealer.
Mmhhhhhh.
  • CC Baxter
22 Aug 2020 12:56 #227169 by CC Baxter
Same as you Andy, it's a machine and it makes mechanical noises. Chris
Time to create page: 0.216 seconds
