Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
  • mattjimny
31 May 2019 11:33 #209306 by mattjimny
Hi guys just wondering if anyone with a 2019 Jimny is noticing a weird grind\rattle noise only taking off in first gear under some load. It doesn't sound like it comes from the gearbox maybe the front axle\hub im not sure.
Cheers!
31 May 2019 11:52 #209307 by Lambert
Welcome to the forum. Could it be a heat shield? Or is it a more determined noise than that. Probably best to get the dealership to examine it, it's what the warranty is for.
31 May 2019 12:57 #209308 by Bill Portland
mattjimny wrote: Hi guys just wondering if anyone with a 2019 Jimny is noticing a weird grind\rattle noise only taking off in first gear under some load. It doesn't sound like it comes from the gearbox maybe the front axle\hub im not sure.
Cheers!
Yes, me. Sounds like it's coming from the rear axle are to me. Does it the 1st time I pull away quite quickly for most trips. I did wonder if I had something loose in the back but can't find anything
  • CC Baxter
31 May 2019 13:55 #209310 by CC Baxter
Mine does it now and again it started at about a 1,000 miles in. The 2008 Gen3 at home does it as well. I suspect the fuel tank shield but refuse to lose sleep over it.
Chris.
31 May 2019 15:13 #209316 by mlines
There is a known issue with knock from the steering when pulling away?
  • mattjimny
01 Jun 2019 09:49 #209374 by mattjimny
Its like a machine gun rattle on take off hey? Im going to get the dealer to check it out
Time to create page: 0.227 seconds
