Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
26 Jul 2020 21:41 #225720 by vagepap
Hi guys, this is my first post here.
I have the same issue with this noise, as described. Anyone has any more details regarding this bulletin?
I want to know in what extend the engineer has to dismantle the transfer box to install/ replace the bearing. I am afraid that more issues will arise from the fix itself.
Thank you for this forum, it is really useful.
  • RobCor
17 Aug 2020 17:24 #226856 by RobCor
Yes, I have the same problem. I have a 2020 Jimny. The noise started almost immediately after I just had it for some weeks. The dealer cannot find anything wrong with it and keeps telling me it’s a common thing with Jimny’s and that they all do that. I of course don’t buy that.
My observation is also that while grinding for that half a second I can feel the 4wd lever tremble.
Mine also does it when I pull out with al little bit more gas and always in first gear when I drive up a hill.
So typically it does it when it needs extra push.
Haven’t tried it in 4wd mode yet because I don’t want to use 4wd on tarmac. It’ll ruin it.
If anyone knows if this is a problem that should be fixed I would like to hear more about it. My dealer doesn’t really seem to care.
Besides this noise, I’m in love with the car. I used to drive premium cars (BMW mostly). But this is so much fun to drive. I live on an island and don’t have highways so this is perfect. You barely drive over 80km/h.
17 Aug 2020 18:23 - 17 Aug 2020 18:23 #226857 by lightning
l've had a lot of experience with Land Rover Defenders and similar noises can occur on those.
Our 2020 Jimny does do it occasionally. lt sounds to me like the clutch spigot bush or release bearing.
lf, as on the Land Rover, there's a splined joint between the gearbox and transfer box it could be that as well, there's a lot of issues with that part on the later Ford engined Defenders.
As the Jimny comes with a three year warranty l wouldn't worry too much about it, if you've reported it to the dealer it will be in the system. So if the noise gets worse they can't say you didn't tell them about it.
Last edit: 17 Aug 2020 18:23 by lightning.
17 Aug 2020 18:37 #226859 by Lambert
The Jimny is remote transfer box, there is a service bulletin that is supposed to fix this.
  • Jimnyz
17 Aug 2020 23:15 - 17 Aug 2020 23:16 #226872 by Jimnyz
I had the same problem with my 2011 manual gen3 vvt. Would make the noise daily in first gear on a steep ramp up to my car park at work. Also happened occasionally on the flat while turning from standstill quickly.
I took it back to the dealer while it was under warrantee at around 15,000kms and they came back first that they couldn't hear it, then I took the mechanic for a drive to demonstrate it. They had it for a day and said that they all do that. My friend also has a 2016 gen3 manual that does it.
I drove that 2011 gen3 for 90,000kms before selling it. The noise never got worse and I just lived with it, so I don't think it results in transfer box failure.
My Gen4 is identical in that it has the same noise on the same ramp. I'm convinced that it's just a normal noise for jimnys now.
Last edit: 17 Aug 2020 23:16 by Jimnyz.
18 Aug 2020 09:15 #226888 by Scimike
Have to ask, did they redesign the transfer box for the G4 or is it the G3 box?
If its the same I would have expected it to be just as prevalent in the G3 community. Cant say I have noticed any noise issues on my 56K G3, but then maybe it is common?
Time to create page: 0.244 seconds
