Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
21 Jul 2021 22:17 #236858 by crash486
Had mine done and now at 20k kms I have the noise in 1st, 2nd and a slightly different noise in 3rd.
Another Aussie is having their TC replaced by Suzuki and yet another Aussie had the input shsft replaced.
Did these sorts of issues occur on previous models?
crash486 JB74W
  • Jimnyz
22 Jul 2021 04:13 #236860 by Jimnyz
Hi Crash486,
I had it on my 2011 Gen 3 as well as my 2019 Gen 4. I took the Gen 3 in to get it checked by the dealer and they said that they all do that and that it wasn't a problem. I travelled another 90000kms on that one and it never got any worse over that time. I noticed it on the Gen 4, but it was about the same, so I ignored it. In both cases, it only happened occasionally on steep inclines at full throttle in first gear, so maybe not as bad as others.
I figured that if it had a complete failure later on, at least they had a record of it for a future repair under warranty.
Cheers, Mike
22 Jul 2021 07:17 - 22 Jul 2021 11:50 #236863 by lightning
ls this rattle noise a sign of "failure" in the transmission or is it just a noise?
Unless it's a sign of impending failure l am not going to bother getting ours done (although it doesn't yet make the noise)
Unless Suzuki have modified the design, any new parts fitted will likely eventually start making the noise again.
Has anyone had this transfer box drive chain actually fail?
Last edit: 22 Jul 2021 11:50 by lightning.
  • coellobranco
22 Jul 2021 07:24 #236864 by coellobranco
Replied by coellobranco on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
Hello, I changed the chain and the noise persists. Now they changed the whole transfer and the noise persists. There seems to be no solution. But there are units that do not have the noise, I do not understand it.
  • Pspies
22 Jul 2021 07:37 #236866 by Pspies
I have had the transfer chain replaced for this noise under a factory recall. It lasted two months then the noise returned. It is back at the dealers again today for them to evaluate.
My view on all of this is that it doesn't affect my driving of the vehicle on or off road but I want it firmly on record in the event there is a major failure.
Funny enough I watch a branch new Jimny be delivered whilst I was there. As the driver of the new car drove off the lot ...Grrrrt ... there was the sound with 0km on the clock,
22 Jul 2021 11:52 - 22 Jul 2021 11:54 #236875 by lightning
Then it could be just a characteristic of the transmission.
Make it known to your dealer that the noise is there, and then just enjoy your car and forget about it.
You want to try owning a Defender, then you wouldn't worry about a bit of a rattle in first gear from time to time.
Last edit: 22 Jul 2021 11:54 by lightning.
Time to create page: 0.186 seconds
