Re:Weird grind\rattle taking off in 1st gear 2019 Jimny
  • CC Baxter
23 Aug 2020 07:31 #227191 by CC Baxter
I started typing an answer to this but I think I fell asleep. It's not the subject, I think it was the cocoa. Chris
  • coellobranco
25 Aug 2020 06:11 #227318 by coellobranco
Replied by coellobranco on topic Weird grind\rattle taking off in 1st gear 2019 Jimny
yes, the same thing happens to me and many colleagues with the Gen4.
  • piggymalone
06 Oct 2020 13:03 #228867 by piggymalone
Same problem on mine (6 months old 4K miles). Only happens when oulling off in first. Intermittent but more noticeable under load such as a hill start or when towing.
I had a very similar noise on a TD5 Defender (which was fixed under warranty) and again on a TD5 Disco at 40K miles (which wasn't under warranty so not fixed). When I spoke to a Land Rover technician they told me that the modification/ warranty fix was to replace the thrust bearing (which is what was done on the Defender) but in his view it wouldn't fail and recommended leaving it until a new clutch was fitted. Since then the Disco has done 150k miles and is still going strong on the original clutch.
I'm taking my Jimny in for some accesories they couldn't fit when I collected the vehcile before lockdown so I have listed the issue to make sure it's logged so even if they can't or won't fix it, I have a record if it ultimately becomes a warrnty issue.
06 Oct 2020 20:29 - 06 Oct 2020 20:32 #228878 by lightning
lt's a fairly common issue with the old Defender and can occur even after a new clutch, thrust bearing and spigot bush have been fitted.
The noise can also come from the spigot bush.
lt rarely causes any issues in Defender and can be left, sometimes the noise will disappear on its own.
l had a new clutch fitted in the Defender last year and the noise occurred after that. The garage took it apart again and fitted another thrust bearing, but it made no difference.
After a few weeks the noise diminished and eventually went away.
Our 2020 Jimny started making this short grinding noise in first gear (right after l posted that ours didn't make the noise!) after a while it was only doing it when the transmission was hot, and now it's stopped doing it.
lf you are worried about it (and there was a time when l would have been straight back to the dealer demanding that they fix it) then report it to your dealer.
Then at least if they elect to do
nothing about it you are covered.
Last edit: 06 Oct 2020 20:32 by lightning.
  • Pspies
07 Oct 2020 15:10 #228896 by Pspies
I have the exact same noise on my three week old my South African 2020 Jimny 1.5GLX Manual.
It went into the dealer today for them to look at. They say it is the transfer case chain. They have applied to Suzuki for a warranty claim and will replace the chain as soon as it is approved.
I will update once it is done and if it makes any difference.
07 Oct 2020 18:22 - 07 Oct 2020 18:23 #228899 by lookonimages
Pspies wrote: I have the exact same noise on my three week old my South African 2020 Jimny 1.5GLX Manual.
I seem to have same issue. Going to take it to dealer tommorow.
Where are you in SA ?
Last edit: 07 Oct 2020 18:23 by lookonimages.
