Tread Lightly
- Thank you received: 305
05 Mar 2022 08:46 #242148
by sniper
sniper
It weighs next to nothing, a few kg, thin wall all alloy construction and even the TB is all alloy. It should be a fair bit lighter than the standard 1300 set up that's currently on it.Really looking forward to seeing what you manage to get from all this. Just out of interest do you have an idea of what it weighs?
sniper
- Thank you received: 2006
05 Mar 2022 11:13 #242150
Replied by Lambert on topic Tread Lightly
Sorry I meant the whole car, you are going to have quite a respectable power to weight ratio when you are done it being a trayback.
05 Mar 2022 14:51 #242152
by sniper
Last weighed in at 1120kg fully fuelled but she's lost a few bits since then....
100 bhp per ton was a goal I chased as a young man, back in the Escort/Sunbeam days. The car feels close to that goal now but we'll find out next week.
Just had a blast to the butchers and it feels pretty quick at certain loads, the current "tune" will run it ok but the fact it has sweet spots means that there is a lot to do and more to get from it.
sniper
sniper
18 Mar 2022 20:55 #242385
by sniper
The car has been at the dyno for a couple of weeks, the first install attempt failed as the crank sensor signal was getting lost just above idle rpm.
I spoke to Riccy who had some problems during the install of his DTA S80 ecu, he had similar issues with the crank sensor which he cured with shielded cables that are grounded to the engine.
I passed that on to the tuner and I'm assuming that no news is good news.... I haven't been told to collect the car lol....
This is the inspiration for the way I have tuned the car... S1600 rally cross engine 218bhp/185nm @8500rpm.
I'm not rich enough to go all steel and forged, so my rev limit is a meagre 6500rpm. I'm also lacking a modified cylinder head and high lift cams so my power expectations are much lower at around 130bhp...
I'm like a kid waiting for Christmas....
sniper
sniper
20 Jun 2022 11:15 - 20 Jun 2022 13:59 #243771
by sniper
The last few month's were sent to me as a trial....
Car goes to the tuner for the standalone ecu install, new induction system and a full map.
Catch covid (all jabbed so just normal flu)
Sensors not available so the new inlet plenum can't be fitted. Decided to tune with std induction.
Car comes back from the rolling road and the gearbox dies on the way home.... New box 2.5hrs away
Gearbox done and not happy with the drive, it's faster by a mile in the mid and upper ranges but part throttle is twitchy and brutal. VVT was not there...
My dicky ticker caused me to pass out during a coughing fit, on the way to a hard landing on my tiled floor, my fleece top catches in the base unit door handle.... I wake up suspended by my waist above twisted legs, my knee was twisted and I was in agony, 12 weeks later I'm still limping...
New granddaughter, "Kiara" born at 8lb6oz.
It's been quite a few months.....
So with gearbox swapped, a slot sorted to go back to the tuners now that I can drive (Left knee so the clutch was impossible)..
1600 VVT with 1300 induction using 1600 injectors, K&N Panel filter, 4-2-1 exhaust manifold, 2" sports cat exhaust...... 98.3 FW BHP / 117ftlb Torque
Kevin at Dynotech plugged the laptop in and we went for a drive and cured all the part throttle problems.... He reduced part throttle fuelling by 30% which as well as curing the brutish behaviour, should save a few pounds in fuel costs.
Kevin also explained a little about the VVT, some I knew but much I didn't, I found it quite informative.
VVT advances the exhaust cam timing, this isn't so much a performance modification as an economy/emissions system for low rev driving. The emissions are lower with reduced exhaust cam timing (valve stays closed longer, more fuel burnt) but as the revs rise, there is a point where the retarded exhaust timing, negatively affects power output (4000rpm on the Jimny). VVT then advances the timing and a modest surge in performance is felt.
The full advance that VVT provides, comes in unnoticeably at 1500 rpm in this tune, nothing additional happens. The benefits (more torque) are there from part throttle to the 6500rpm red line.
The race inlet is being fitted up with sensors and will be fitted in the next month or two...
A little disappointed that it didn't break 100bhp but that's all in my mind.... The important figure is the 117ftlb of torque which makes the car nippy and capable... 5th gear at 25mph and pulls cleanly from 1800rpm.
For what it is, the Jimny is now a pretty quick car and even more fun..... Harassing big 4x4's is not a new pleasure but I can out accelerate the V8's now.
Now to do a few numbers and see if I can afford the Big Jimny meet...
sniper
sniper
Last edit: 20 Jun 2022 13:59 by sniper.
20 Jun 2022 13:28 #243775
Tell the financial department that it's a mental health retreat and will make you a better person to live with, works on mine.
Time to create page: 0.214 seconds
