Tread Lightly
5 years 7 months ago #234332
Replied by Riccy on topic Tread Lightly
Bump stop info for John...
Measure up first. The cut you make depends on the spring size drastically (and its when the spring is under normal load with all 4 wheels on the ground. Remember the air bump has (in theory) a 2" travel distance to be allowed for as well.
Cut off the original bump stop at the point shown in the pics. Use Holesaw on drill to go through and up out the top of the chassis spring seat. Fit it inbetween and use the adjustment to sort out bottoming out to a point your happy with. I found that with the long 2.0x8 fox shocks I needed it set at max down to stop the shocks bottoming out. If I wanted to fit bigger springs than the current +3" jimnybits ones, then I would need to extend the bump stop original tube to get it sitting lower down. This would be so it acts before the spring fully compresses.
The metal collar on the terrafirma air bumps is intended to be welded to the car and therefore comes uncoated. Something I regretably missed, and now mine is rusty
Finally the nitrogen in them can be adjusted. I have set mine to 200 psi (half their factory setting i think). This is because they were far too stiff at first and gave a really harsh ride. I have nitrogen and regulator if you are stuck
Finally the nitrogen in them can be adjusted. I have set mine to 200 psi (half their factory setting i think). This is because they were far too stiff at first and gave a really harsh ride. I have nitrogen and proper regulator/attachments in the garage if you are stuck
5 years 7 months ago #234333
and braced tubes?... better go the full hog then
Rear has bottom brace, radius arm & panhard brackets reinforced and shock mounts drilled right through.
Front has top brace, bottom spine, reinforced radius arm/panhard brackets and swivel mount brace.
5 years 5 months ago - 5 years 5 months ago #235347
by sniper
Wales scenic with the "Jimny Jaunts" team. Brett, Riccy, Dave and Dave.
Lots of driving and not many pictures.....
The car went to ICE4X4 in Bolsover for fresh brakes and a check over/prep for it's first serious drive since the build was finished. It was supposed to be having the Terrafirma air bumps fitted but the guys said that the car just doesn't have the weight to warrant such H/D bump stops. At only 1100kg and hoping to get lighter, they feel that the existing suspension set up will cope perfectly...... We'll see....
Set out at 5.15AM for the meet up at the cafe near Dave Jones' place in St Asaph. Nice drive across the Peaks and hit the motorway at Stockport.... Steady drive at 70-80mph for the next hour and the car is behaving perfectly, ICE4X4 have got the car feeling sharp with no rattles and bangs at all, as enjoyable as a two and a half hour drive can be... in a Jimny.....
Dave's "Boogie" looked great and very capable but very cold..... He was kitted up well to keep the cold at bay. Riccy's truck has had a freshen up recently and his pick up looked sharp. Jalapeño was the same mismatched panel monster I saw last time. Dave "The Bee" had a gently lifted 05 Jimny with smaller muds....
Sadly we lost Dave and the "Boogie" after the first few lanes. The head gasket failed and after stopping to cool down and say farewell he had a gentle drive home, under his own power. Luckily the failure happened close to home....
The four of us went on to enjoy the days "scenic" driving.... Both myself and Brett lost our snorkel tops to the same tree branch, one lane needed low box and one which was T&S (you would have to force your way through as a pedestrian) and not much more that a footpath wide....
Great first drive in Wales and if that was a "scenic" trip.... I can't wait for a more serious trip later in the year, including the notorious "Hendryd"....
A small dent on the A pillar where the snorkel copped it, otherwise unscathed. 70-80mph all the way home with no issues.
Great to see some old friends and make a new one...
sniper
sniper
Last edit: 5 years 5 months ago by sniper.
5 years 3 months ago - 5 years 3 months ago #237560
by sniper
Bottom pulley failed.... Luckily I was just local and I limped it to the barn without getting hot. On inspection, it was clear that the bottom pulley was out of line with the other pulleys. The belts were also intact with no obvious reason for jumping off....
So new parts were ordered:- 850 v-belt, 833 v-belt, bottom pulley, tensioner, radiator, radiator cap.
Lucky to have access to the barn and tools now, so I can do a few bits myself, my weak heart cannot tolerate the effort needed to undo bolts of any decent size but I was ok taking the radiator out.... Richard Kisby, (my best buddy who I share the barn with), was on hand for the bottom pulley bolt, tensioner and alternator bolts or I would still be there lol..
Rebuilt waiting for Richard to tighten up.....
With help... it was rebuilt and filled with no air locks, all good....
Ready for the Wales trip and Hendryd, with Brett, Riccy and Nick (in a tricked out gen4), from the Jimny Jaunts group, a trip I have been looking forward to for a couple of years...
Down at the barn yesterday doing the pre trip prep for Wales and still searching for an annoying rattle (developed on the coast to coast)..... Searched and shook everything but couldn't find anything....
The car was MOT'd with only a number plate light needing to be swapped last week, so I hadn't even considered that the rattle could be coming from a hub..... but it was... near side wheel bearing is shot....
No spares to hand and only 12hrs to go before a big day out.... I had to cancel the Wales trip....
Spares are on order with James, so should be here by midweek....
Playing in the mud at the bigjimny meet has come at a price lol.
sniper
sniper
Last edit: 5 years 3 months ago by sniper.
4 years 10 months ago #240898
by sniper
Having sold the 11' plate cat D repaired Jimny and made a modest profit, it has also released the cash that has been tied up since May....
Shopping trip in Singapore....
That alongside an RZ racing 70mm throttle body with a standalone ecu which is being installed and mapped at Dynotech in Ripley... I'll be booking it in as soon as I get a delivery date for the manifold and TB.
So new injection system, standalone ECU and fully mapped.... Fingers crossed, there may be enough cash left to get the front cage and seats done as well...
sniper
sniper
4 years 10 months ago #240902
Time to create page: 0.154 seconds
