Ulysses
Started with scraping and cleaning back the cage, pickup bed and various bits. All liberally coated with the rust coverter solution and left to dry. Later on cleaned and brush painted with Buzzweld RCP this time. Second coat needed, but that will be tomorrow now. Ive cosen brush as it goes on much thicker than with the scultz gun method I used last time round, hopefully producing a better coverage. Happily the textured finish of the remaining raptor paint shows though pretty well.
A little progress today (or looks a little).
And something I have been keeping quiet about for a while. When I fitted the floating rear conversion I had a load of hassle with different brake caliper setups to get it right. I also had to grind a bit of the plate away to allow the ABS sensor to fit in properly. It had been annoying me that they we less than perfect, so I designed and had made my own version, specifically to suit the renault rear disc conversion nearly everyone has now.
They fit well and are made from Aluminium (steel possible also). Happy with them now
- Thank you received: 1811
Then its put it all back togther next weekend hopefully
Look forward to seeing it in Wales....
sniper
- Thank you received: 663
Or a different brand
Looks good
Mine needs a paint job
So yesterday I managed to finish off the red properly and remove masking. Pleased with it. I think its a deeper red than the first time, even though its supposed to be the same RAL colour.
Then attacked the front end behind the winch bumper with RCP and WAR topcoat. lovely thick stuff Bumper got a dosing of the rust convertor stuff to work its magic while doing the underbody bits.
While the winch was out and everything else getting smartened up I decided to do that too. Stripped it, etch primer and then a WAR aerosol 'signal red' this time (was a lucky dip aerosol from buzzweld). Its come up well too...
Then more black raptor on the bumper and bonnet plates to smarten everything up:
and I know I keep saying this... but its going back together next weekend hopefully
Raptor mate, I have all the gear for it and am used to using it now. You can borrow the compressor setup if you want to try your hand at painting yours with raptor. Pretty cheap and easy to do. A 4 bottle kit should do the car if your not changing colours easy enough. £84 black or £107 any colour at buzzweld.co.uk for a 4 bottle kit...jackonlyjack wrote: Did you go with raptor again pal
Looks good
Thanks mate, hopefully it will last this time Lesson learnt about proper primer and suchlike now hopefully.sniper wrote: Spot on finish Riccy, it looked the dogs doodaa's when first finished.... Something about your pick up makes it look big, more substantial, maybe the flareside style bed.... Always liked it....... A bit too much really lol, especially if you ask the finance fhurer....
sniper
I think it looks bigger because of the external cage which goes onto the bumper. Its not actually much wider.
Yours is nearly a full cage now and has the nice big, wide Keithy spec front arches, a fine choice
Could you tell me the set up you're using i might go and buy one
Thanks
- Thank you received: 923
- Thank you received: 115
