Ulysses
- Thank you received: 923
25 Jul 2021 08:59 #236947
Amazing work once again Riccy!
- Thank you received: 115
26 Jul 2021 15:04 - 26 Jul 2021 15:05 #237001
by maverick
Jalapeño, IISY?
Great work there Riccy ... Time to service my Transfer Box please, and maybe start a side-line on making Rock Lobsters
Jalapeño, IISY?
Last edit: 26 Jul 2021 15:05 by maverick. Reason: typo
- Thank you received: 1970
26 Jul 2021 17:59 #237008
Ooh 6.4 gears and a torque converter that would make Temeraire unstoppable if a little slow. Stop giving me bad ideas!
01 Aug 2021 18:03 #237232
Replaced the gearstick bobbins with some poly versions as the rubber ones had split again. These seem more suited in terms of stiffness and work well for a cheap thing. They are classic mini exhaust hangars and about £4ea on ebay.
And some more work on the idle speed control gadget:
- Roger Fairclough
- Thank you received: 224
01 Aug 2021 18:55 #237235
by Roger Fairclough
Replied by Roger Fairclough on topic Ulysses
Riccy.
I am intrigued with your new bobbins. Are they two separate studs with welded on washers or a straight through section of all thread rod.
Cheers
Roger
Cheers
Roger
01 Aug 2021 19:03 #237236
Im not sure Roger. I used the orange poly ones and got the rubbers ones as spares.
The poly ones look like a thread all the way through, though without cutting them apart I cant be sure. The washers are loose on these ones.
The rubber are a thread welded to the washer and then rubber bonded between the two sides.
Time to create page: 0.238 seconds
