Ola`s jimny project
09 May 2018 05:53 #192536 by yakuza
OlaGB wrote: Winch mount done.. Pleased with the result!
Not sure if ill change to syntetic rope or just buy a fairlead for steel wire yet.
Had to remove the A/C fan to make room, but thats it..
Nice and tight!
No AC fan? Will that make the AC less effective only when not moving maybe?
I would still try to get a rope to replace the wire.
  • OlaGB
09 May 2018 06:27 #192539 by OlaGB
Nice and tight!
Yes, thats what i`m hoping for, that the AC will work as before unless i`m standing still.
There is room for a smaller fan , but i dont care much about it..
If the motor shows to run hot in offroad use, i`ll make a manual electric fan instead..
Syntetic rope looks like the way to go for safety! But there`s pro`s and con`s for both..
Theres everything from heat issues, alu fairliead that gets damaged if the hook is pulled into it (needs to be hooked to the tow point at all times), and contamination from the road etc..
Both alternatives probably needs a sack over the winch for longevity and less maintenance.
11 May 2018 21:37 #192608 by Busta
Bit late noticing it, but nice to see somebody has used my bolt in the hub locking technique!
The following user(s) said Thank You: OlaGB
  • OlaGB
12 May 2018 03:34 #192611 by OlaGB
Busta wrote: Bit late noticing it, but nice to see somebody has used my bolt in the hub locking technique!
Found the idea on Youtube (
) , but didnt know it was you! :)
Worked just as supposed, and was a very quick fix! Thanks for putting it out there.. (If the YT vid wasnt you, it might be based on you`re idea anyway)
12 May 2018 09:14 #192613 by jackonlyjack
That's a good quick fix idea Busta ;)
6.8mm drill is correct size for m8 tapped thread
12 May 2018 16:50 #192627 by Busta
Yes that's me. I've put a few random Jimny videos on YouTube. Nice to see they are useful :)
Yes Jack, 6.8mm is correct but in this instance it is not critical. There is very little force on the bolt.
Time to create page: 0.323 seconds
